Thread: 1.25 Cr - 0.5 Mo High Temperature Application
    Dear All,
    I have a basic doubt for 1.25 Cr - 0.5 Mo.At high temperature application, many specs ask to use SA-387 Gr 11 CL1 in stead of CL 2.
    Why? i.e., what property does CL 1 have better than CL 2 at higher temperature, so that CL 1 is preferred over CL 2
    Re: 1.25 Cr - 0.5 Mo High Temperature Application
    CL2 has bigger tensile strength so is more expensive so if don't need don't spend money
    CL2 has more control on % of composition so you need to have a more controlled welding process if u want to keep mec prop.
  1. Multiphase pumps, high GVF application
    By SW LING in forum Oil And Gas Process
    Last Post: 09-30-2013, 04:33 AM
  2. High Pressure/ High Temperature Pipe Hydrotest
    By jigs36 in forum Mechanical Engineering
    Last Post: 05-23-2013, 04:08 PM
  3. High Pressure and High Temperature Wells
    By ahmed08pg17 in forum Home Articles
    Last Post: 05-23-2013, 08:41 AM
  4. High temperature in boiler wall
    Last Post: 05-16-2011, 06:57 PM
  5. Mechanical Properties at high temperature
    By mri44 in forum Mechanical Engineering
    Last Post: 04-04-2011, 04:58 PM
