Thread: High Pressure/ High Temperature Pipe Hydrotest
    Dear All,
    I am looking for procedure or common practice to determine hydro test pressure of High Pressure and High Temperature service pipe.
  3. Re: High Pressure/ High Temperature Pipe Hydrotest
    I believe that ASME sec V has the answer for that. In the appendix VI, Pressure change testing the procedure is given and also refers to the clause T-1044, in page 158, as the pressure should not exceed 25% of the design pressure unless otherwise stated in the mandatory requirement for the job.
    ASME B31.3 also addresses this, you should see which is your construction code.
  1. Gas Plugs/High Lift Flange for Hydrotest
    By kavimagi in forum Pipeline And Fluid Flow
    Last Post: 10-10-2013, 09:33 PM
  2. High pressure and temperature steam pipe
    By cardin94 in forum Materials Science &Corrosion
    Last Post: 07-04-2013, 12:28 PM
  3. High Pressure and High Temperature Wells
    By ahmed08pg17 in forum Home Articles
    Last Post: 05-23-2013, 08:41 AM
  4. Pipe bend for high temperature line
    By mlk in forum Pipeline And Fluid Flow
    Last Post: 01-21-2012, 05:14 PM
