Thread: Looking for info about PED directive pressure test value
  1. Looking for info about PED directive pressure test value
    Dear all,
    it's my first thread so I apologize if it's not as a thread should be.
    We're design a line with Ts= 530 °C and Ps=30 barg. The line will transport compressed air and will be in AISI 304.
    We are looking for a hand to define the lowest pressure test value that compliance the normative.
    The 97/23/CE (EN 13480-5) state that the pressure test should be:
    P test=max (1.43 * Ps; 1.25*Ps* ftest/ft)
    It's not clear whic f test I have to use.
    Someone can help me?
    Moreover, someone knows some statement to reduce the P test in accordance with some regulation?
    Thanks.
    Re: Looking for info about PED directive pressure test value
    Hi Giorgino
    The PED is very clear the pressure test to be adopted and used is the highest value of the two.
    However, you would need to check and ensure that standard rated parts such flanges are not over stressed due to the test pressure.
    Quote Originally Posted by giorgino View Post
    Dear all,
    Thanks.
  5. Re: Looking for info about PED directive pressure test value
    Dear all,
    f is the design stress, which is calculated in accordance with EN 13480-3 chapter 5.
  6. Re: Looking for info about PED directive pressure test value
    Dear all,
  1. Well test analysis info.
    By tortanvir in forum Oil And Gas Production
    Last Post: 08-08-2012, 12:01 AM
  2. Pressure Equipment Directive
    By lochandadhich in forum Mechanical Engineering
    Last Post: 02-25-2012, 01:34 PM
  3. PED - European Pressure Directive
    By EJeng in forum Mechanical Engineering
    Last Post: 11-27-2009, 01:08 AM
  4. Pressure Equipment Directive EC 97/23
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 02-06-2009, 10:38 PM
