I m currently executing a water bath heater(WBH) for one of our client.
WBH shell is an atmospheric vessel(3200 ID X 6500mm long).
It contains a coil bundle at top which has crude oil flowing inside (Operating Pressure 3 to 5barg @ 25 to 45degC).
This crude oil will be heated by the water bath in the WBH shell.
Water will receive the heat input from fire tube placed at the bottom of the WBH shell.
Coil is designed for 25barg @ 100degC & will be hydrotested for 1.5 times the design pressure.
it is ok till now.
But the problem is that client is also asking us to design the WBH shell for 5barg @100 degC & hydrotest it @1.5 times the D.P.
Which we feel is neither the good engineering practice nor economical also.
WBH shell is an atmospheric vessel and in general practice it is designed for FULL of water & also hydrotested @ full of water.
Client told us that although the WBH shell will never ever be subjected to pressure in its entire life period but they are considering 5 barg design pressure for WBH shell because of tube/coil rupture case.
I request to all of you please give your view on this ( WBH Design pressure & hydrotest pressure).
We don’t want to go with so much high design & hydrotest pressures because it is not economical for us.
How can we convey our end client?
Thanks for giving your valuable time in reading this long post.
Appreciate if any one can revert with your vies on this. please!
Coil is designed for 25 barg with corrosion allowance & it has MAWP=32barg. How could rupture occurred? When operating is just 3 to 5 barg.
Also there is PSV( Set pressure @ 25barg) on crude oil line.
