Thread: Basics in grounding system design - focus on IEEE std80
    Since the early days of the electric power industry, the safety of personnel in and around electric power installations has been a primary concern. With ever increasing short-circuit powers and, thus, fault current levels in today typically interconnected power systems, there is a suitable renewed emphasis on safety.
    The safety of people may be compromised by the rise in the ground potential of grounded structures during unbalanced electric power faults. In such conditions, humans touching grounded structures can be subjected to high voltages.
    Safe operation of electrical installments calls for a properly designed and installed earthing and grounding system, in order to ensure that the magnitude and duration of the electric current conducted through body are not sufficient to cause ventricular fibrillation.
    In general terms, and for substations in particular, a proper grounding path of low impedance ensures low potential rise and also a fast clearing time for faults (a fault remaining for long within a system may cause several critical issues, including those related with power system stability. Thus, faster clearing improves overall reliability, more than ensures better safety, because any person coming into contact with available metallic parts and/or metallic enclosures is exposed to higher risk increasing potentials and fault durations).
    Here attached a small introduction to grounding system design, especially following IEEE std 80.
    Moreover I attach the link for downloading a pdf copy of the MILITARY HANDBOOK - GROUNDING, BONDING AND SHIELDING FOR ELECTRONIC EQUIPMENTS AND FACILITIES from which some interesting concepts can be added to those included in the std80.
    This last document should be copyright free
    I will try to complete the measurements section and, possibly, prepare some worksheet for simple calculations.
    hope this can be of use for someone,
    Attached Files Attached Files
    Sent from my iPhone using Tapatalk
  5. Re: Basics in grounding system design - focus on IEEE std80
    Thanks, very usefull
    This one is also usefull:
    Practical Grounding, Bonding, Shielding And Surge Protection (Practical Professional Books)
    by Butterworth-Heinemann (2004)
  1. Industrial Power System Grounding Design Handbook
    By mdm in forum Electrical & Power Engineering
    Last Post: 08-28-2015, 03:56 AM
  2. IEEE instrumentation and control grounding in generating stations
    By blacksnow in forum Instrumentation & Control
    Last Post: 02-12-2014, 09:19 PM
  3. Grounding System in PowerStations.
    By jperater in forum Electrical & Power Engineering
    Last Post: 08-11-2013, 09:53 PM
  4. Industrial Power System Grounding Design Handbook
    By f.ghezeljeh in forum Electrical & Power Engineering
    Last Post: 07-29-2013, 08:29 PM
  5. Grounding Basics for Instrument Engineers
    By bathulagopi in forum Instrumentation & Control
    Last Post: 07-24-2013, 01:08 AM
