Thread: Grounding System in PowerStations.
  1. Exclamation Grounding System in PowerStations.
    Hi guys,
    I need help in the grounding system for PowerStations. We have a Combined Cycle Gas Turbine Project with 2-250 MVA Gas Turbine and 1-250 MVA Steam Turbine. I have a few questions.
    1. How do I design the grounding grid for the PowerStation?
    2. How to compute for the max fault current and fault clearing time for the Grounding design?
    3. Shall I consider the schedule of loads of the plant?
    4. Is the grid for LV/MV and EHV systems separate?
    I couldn't find a book which discussed the grounding systems for powerstations. Thanks for the help.
    Re: Grounding System in PowerStations.
    The best and most complete guide for any earthing system is the IEEE 80-2000
  5. Re: Grounding System in PowerStations.
    The Ground Bus Should be common to all the Levels of Voltage except Instrument Earthing (Clean Earthing), Refer to IEEE 80, this is a good standard for Grounding
    see IEEE 837 Grounding substation
    use ETAP software
    or free
    IEEE-80 TOOL v1.0b
    hxxp://search.4shared.com/postDownload/MyFwHtWW/IEEE-80_TOOL_v10b.html
  1. Industrial Power System Grounding Design Handbook
    By mdm in forum Electrical & Power Engineering
    Last Post: 08-28-2015, 03:56 AM
  2. Basics in grounding system design - focus on IEEE std80
    By garrison2711 in forum Electrical & Power Engineering
    Last Post: 02-09-2014, 11:24 AM
  3. Industrial Power System Grounding Design Handbook
    By f.ghezeljeh in forum Electrical & Power Engineering
    Last Post: 07-29-2013, 08:29 PM
  4. Software grounding
    By mertseger in forum Electrical & Power Engineering
    Last Post: 07-17-2013, 09:34 AM
  5. API standard for Electrical Grounding
    By Parthasarathy.R in forum Electrical & Power Engineering
    Last Post: 06-06-2010, 05:26 PM
