Thread: Simulation model QC
    Simulation model QC
    Dears
    When we finish a simulation model and run it
    what are the steps to evaluate and check that model
    Re: Simulation model QC
    I'm not sure what you mean by "finish a simulation model ". I suppose "finish" means to history match the model. If so, right after finishing the history matching, and prior to make any prediction of future performance I always check that the cumulative material balance error (MBE) is less than 1%. This limit might vary from one company to the other, but this is the one I use. Go to the simulator's manual and read how to report this MBE.
    Jan 2009
    ALA, KZ
    First of all first check is inplace numbers they should be close to one you have in geomodel.
    the Net volumes and poro volumes will tell how accurate you did upscaling
    while different in sw will tell how accurate you done pc functions.
    Check your end points ( swi, sor) since they will dramatically effect to sweep factor which will lead to unrealistic forecast recovery factors
    Check you real perm curve exponent
    If you will have errors during calculation check you pvt and pressure data
    Check rock compressability , overestimating of it might result to unrealistic pressure support
    Check you permeability with KH test
    then check your History production /injection data vs calculated
    then check your pressure data history vs calculated.
    Once all data is in agreement
    Congratulation you set up your model !
    Dears
    Thank you for your great advice
    All the best
  1. Replies: 2
    Last Post: 05-08-2013, 08:48 AM
  2. Simulation model initialization & Oil in place
    By dquento in forum Reservoir
    Last Post: 02-25-2013, 02:15 PM
  3. Pressure in the simulation model
    By bayan in forum Reservoir
    Last Post: 12-11-2012, 04:31 PM
  4. Please help in simulation model
    Last Post: 12-11-2012, 11:02 AM
  5. Use of Permeabilty in Simulation Model
    By dipak_m in forum Reservoir
    Last Post: 11-10-2010, 12:48 AM
