Thread: Test separator
    Test separator
    Hi all,
    Which type of three of three phase test separator are more robust/accurate when liquid carry over in the gas line or gas carry under in the liquid line occur ?
    Is it recommend to use test separator using coriolis meters or turbine meters ?
    And who to avoid or minimize this problem (liquid carry over,gas carry under) ?
    Re: Test separator
    Dear Triviaux, all depends on which kind of fluid would you like to measure, crude oil + water + diluent+ chemical + gas + among other rates of fluid. Also, you need to be clear about operational envelopes of all market equipments avalilable. Try with multiphase meters.
    Re: Test separator
    Dear Oswaldo ,
    Thanks for your reply , regarding the type of fluid to measure its a multiphase flow (oil/gas/water flow) in my project the test separator will be our reference to evaluate the performance of severals type of multiphase flow meters this is the reason the accuracy must be irreproachable
    Re: Test separator
    Dear Oswaldo ,
  1. 3 Phase separator software..SEP-Calc® Separator Design Suite
    By mzafar in forum Oil And Gas Process
    Last Post: 01-15-2015, 08:28 PM
  2. Adhesion test to ISO4624 (pull off test)
    By blasterblaine in forum Quality management
    Last Post: 01-13-2015, 09:57 AM
  3. Replies: 3
    Last Post: 05-15-2013, 03:34 PM
  4. CO2 Concentration Test - Full Discharge Test
    By uzbarry in forum Safety And Environment
    Last Post: 05-26-2011, 02:58 PM
