Hi Everyone
I have tried many adhesives for coating adhesion tests with varying degrees of success.
Does anyone know of superior strength epoxy or cyanoacrylate adhesives that will provide readings in excess of 15MPa
Many thanks
Hi Everyone
Many thanks
interesting question,
do you have any (other than strength) specific requirements? ie environment, operation, temperature, material coated on etc
there seem to be plenty of adhesives out there, one of the best supplier I would think would be 3M
If I understand correctly you are attempting to test a coating for adhesion integrity. If that is the case, the Standard Military adhesion test is to apply Tape manufactured by the 3M company. The Tape to use is 3M 250 Tape. You firmly apply a section of the tape and quickly and firmly remove it. The paint should not be removed.
