Thread: Water cut Resources please!!!!!!!!!!
  1. Post Water cut Resources please!!!!!!!!!!
    hi guys,
    I would very much appreciate your help with regard to any resource or source on Water cut.
    -Warren J.E 1998, A simple Model for Predicting the performance of Complex Field,
    -Purvis R.A 1985, Analysis of production performance Graphs.
    Nov 2008
    Australia
    You'll have more luck with this request if you are more specific in the information you require.
    Information on watercut? It is water rate / fluid rate..... end of story
    Now, if you were after ways to predict watercut evolution in pattern waterfloods, cusping/coning situations, edge water drive reservoirs etc, then these are all different questions which you need to better communicate
  5. Tanx
    well i would like papers on water cut prediction.
    Thanx for your input.
    my friend usually they get the water cut from no. of test
    1) They take sample (visual ) then they estimate water cut
    2) Also using MSV auto test to get the water cut (red eye)
    3) Haimo test used too to get the water cut
    4) coriolis used an another tool
    prediction of water cut you can use decline curve analysis as simple method
    by plotting cum oil vs. wc in semilog until the economic limit
    if you have simulation model for sure you can predict any thing as you have your
    operation conditions set
    may be you can use fractional flow so you can get the WOR from that for sure you do need the rel perm data , as dykastra-pasron method
    hope it is helping you,
  1. Manufacturing & Design Resources
    By selmagis in forum Mechanical Engineering
    Last Post: 04-22-2012, 05:14 PM
  2. Water Resources Health Environment and Development
    By Derek1 in forum Petrochemical
    Last Post: 12-13-2008, 01:58 AM
  3. Unconventional gas resources
    By ilno in forum Reservoir
    Last Post: 11-01-2008, 06:29 PM
