Results 1 to 6 of 6
Thread: Process Simulation Engineer (how to switch over to reservoir simulation)
  1. Process Simulation Engineer (how to switch over to reservoir simulation)
    Hi,
    I am currently working as a process simulation engineer for oil and gas sector. can i switch over to reservoir simulation with this experience. If not what are the things i have to prepare so that i am elligible for applying reservoir engineering jobs. Could any one can guide me.
    Thanks in Advance
    With Best Regards
    Subramonian P
    Re: Process Simulation Engineer with +4 years of experience
    Since you get no answer from anyone else I decided to write my own comments. 8 years ago I met a friend with a BS degree in Petroleum Engineering who worked as a process simulation engineer. He used to use Hysys to design facilities, flow lines, etc. That was his first job after graduation. He definitely didn't like it. He works now, 8 years later, as a company man in drilling operations. That's what he likes and that's what he does now.
    You can definitely swith to reservoir simulation.
    However, I'll also be honest with you. I extremely doubt that the experience you're making now as a process simulation engineer will be useful in you CV when it comes to apply for a position in reservoir engineering. I mean it won't give you any advantage to get a position as a reservoir simulation engineer. Those are two different field areas and you should start by preparing yourself now. The longer the time you work in that area, the less the expectations you have to become a reservoir simulation engineer in the near future.
    By the way, what's your background? Petroleum Engineering? if so, you have more chances to make the switch that you want.
    Good luck!
    No - they are different packages & experience is not directly relevant.
    Process Simulation packages - Hysis, Pipesim, Olga, Pipephase etc
    Reservoir / Petroleum Simulation Packages - Prosper, Eclipse, Petrel etc
    Re: Process Simulation Engineer (how to switch over to reservoir simulation)
    No - they are different packages & experience is not directly relevant. Process Simulation packages - Hysis, Pipesim, Olga, Pipephase etc
    GuL
    Jan 2009
    ALA, KZ
    My background - Economics i spent 5 years of my life to get a degree in economics
    After 5 years working in this area I sweetched to reservoir since economics become for me not entreseting
    After 7 years in industry i got my PhD in production and now i can solve problems with black oil and compostional srating from siecmic and ending econimics
    The key for you is you will to progress as an engineer
    Once you have it the everything else you will defiantly find
  1. Reservoir Simulation
    By aliali in forum Reservoir
    Last Post: 07-09-2014, 09:42 PM
  2. How to be a good simulation engineer?
    By punj_re in forum Reservoir
    Last Post: 10-07-2013, 04:57 PM
  3. Reservoir simulation little help
    By Petrol4 in forum Reservoir
    Last Post: 03-29-2013, 02:09 PM
  4. Help : Reservoir Simulation !
    By jikzo in forum Reservoir
    Last Post: 12-31-2011, 11:05 PM
