The impact breaker replacement parts: impact breaker replacement parts, the first open put on the shelf. When using, first will put on the shelf in the box with the connecting bolt, and then unloaded with wrench to flip device parts, and hex head slowly open shelves. At the same time, it can use at the top of the frame hang a device for ransom. Repeat the process, namely close put on the shelf. The impact breaker plate hammer: counterattack broken plate hammer wear enough should adjust or replaced, in order to avoid the damage and other components fasteners. The impact breaker line board: open the cover, dismantled after fixed fight back with the lining board split cotters, slot of nuts, bolts, it can wear the counter after lining board replacement.
The sand production line, the impact crusher is the third working procedure, after mandibles crusher broken, then the material to counterattack crusher, once again after breaking up into customer 20 to 60 mm particles. The impact breaker is a use of impact energy to stave machinery. To ensure that the impact breaker, better in the sand in production line of continued operation, continue the service life of the impact breaker, users should be to counterattack crusher frequently maintain and maintenance. In the new investment after the operation, the shift to counter must be broken for a full inspection. After a week on the run counter the motor lubrication, a full inspection.
The content of the examination including fixed parts of the situation, tighten belt transmission, bearing seal, fight back foils, of lining board of the wear put a check of all maintenance cycle, and combined with a regular maintenance and replacement system. The[link Point to another website Only the registered members can access]
screw classifier:[link Point to another website Only the registered members can access]
