As a leader of crusher industry, Henan Hongxing Mining Machinery Co., Ltd. put innovation as the leading, formed the independent innovation, the supremacy of credibility has high credibility brand-name enterprises, and the enterprises have maintained a sound momentum of development. At the same time to speed up the establishment of enterprises as the main body, the market as the guidance, the combination of technical innovation system, promote the transformation of scientific and technological achievements into productivity, which is the fundamental reason for the rapid development of Hongxing Machinery. Following I will introduce you Hongxing[link Point to another website Only the registered members can access]
Cone crushers are sometimes called gyratory cone crushers. Cone crushers crush rock between two conical surfaces called the mantle (lower movable surface) and the concave liners above. These surfaces do the actual crushing and are constructed of high manganese steel. Cone crushers can be used in a primary crushing role but are typically seen more often in a secondary or tertiary position.
The greatest advance in cone crusher development is the application of hydraulic technology. Hongxing cone crusher hydraulic system can protect against non-smash items into the crushing chamber. For example, iron and steel can cause a large area of cone crusher damage, and caused more cost consumed in the production. The progress of the hydraulic system greatly reducing downtime and improve the using life of cone crusher machines. So the hydraulic cone crusher are gradually get quarry site customers’ favor, such as cone crusher in China, cone crusher in India, cone crusher in Africa, cone crusher in South America, etc.
Impact crusher is usually for secondary crushing. Moreover, impact crusher has the feature of shaping! In other words, if you want a very good cubical shape of your final products, then impact crusher is just what you want! Generally, feeding size of impact crushers can't be more than 500mm. Besides, the smaller pieces of the feeding stones, the higher of the capacity and the lower wear costs of the impact crusher.
calcium silicate board equipments:[link Point to another website Only the registered members can access]
