Thread: Sonic velocity and choked flow
    I have got a confusion w.r.t to the sonic velocity and choked flow equations given in the literature. Using choked flow equations (mass flow) given in safety literature and divide that mass flow with the area of opening and density of the gas, we should get the velocity of the gas which should be near about the sonic velocity. But what I am getting is a velocity which is well below the sonic velocity (which can be found out using the relation sqrt(gc*k*R*T/Mol wt of gas). What may be the reason?
    ssk
  3. Re: Sonic velocity and choked flow
    Difficult to say, which correlations did you use?
  1. Multiple choked flow in PSV tail pipe
    By nasermashti in forum Oil And Gas Process
    Last Post: 08-25-2013, 12:23 AM
  2. Recommended Delivery Flow Velocity of Viscous Liquids
    Last Post: 03-01-2012, 05:52 PM
  3. Boiling Fluids - Recommended Suction Flow Velocity
    Last Post: 01-26-2012, 01:38 PM
  4. Boiling Fluids - Recommended Suction Flow Velocity
    Last Post: 07-26-2011, 10:29 PM
  5. Viscous Fluids - Recommended Suction Flow Velocity
    Last Post: 07-26-2011, 05:19 AM
