Dears,
Is it possible having multiple choked points in PSV tail pipe?
Dears,
Pressure drop in psv tail pipe (build up back pressure) is limited by the psv type. For example, if psv is conventional your total back pressure can't exceed 10% of psv set pressure. For balanced bellows and pilot psvs total pressure drop is higher (30-50%) of set pressure. Read API 520 and 521 and consult psv vendor for a maximum allowed back pressure for particular psv.
