Hi,
I am in need of data file to run any of the following pattern schemes in eclipse 100.
1. 5 spot
2. 7 spot
3. 9 spot
Kindly provide me because this will help me during my studies project.
Thanks in advance
Hi,
1. 5 spot
2. 7 spot
3. 9 spot
Thanks in advance
Just build one. If your project involves use of Eclipse, you are going to have to learn how to use it anyway..... Simple simple simple.....
QFIVE.DATA in the eclipse/data deck installed by default should get you started
If you are able to use CMG software (IMEX for Black oil simulation), I could tell you how to built conceptual pattern models (5 spot or 7 spot or 9 spot well pattern) in a few minutes.
I have CMG , but I have never used it, I have eclipse and S3graph.......
