Thread: Sizing of relief valve for LPG bullet
    Dear all,
    Please help me. I have an issue with basics.
    Problem follows:
    Make a spreadsheet for the sizing of relief valve for commercial LPG bullet (mainly propane) using API 520. Temperature of atmosphere where the bullet is kept (above ground) varies from 10°C to 35°C (50°F to 95°F).
    Which procedure in API 520 should I use?
    >procedure for liquid OR
    >the procedure for vapor-liquid?
    As u know, in API 520, different procedures are given for - critical, sub-critical flow, liquid relief, sizing for two phase liquid or vapor etc. So I am confused:-(
    The LPG bullet would be filled 85% of their water capacity, the remaining space being taken up with vapor (as I read from some websites).
    (I already made the spreadsheet for various conditions given in API 520. But I need to choose which procedure to use specifically for LPG bullet )
    If I haven't given enough info to solve the problem, please let me know.
  3. Re: Sizing of relief valve for LPG bullet
    This depends on the overpressure scenario's you have identified and quantified, for fire you would use the vapour sizing equations but for overfilling you would use the 2-phase equations.
    So, was this part of your job/work or you're doing it for school or for fun?
  1. D.r.e.s.s.e.r. R/a/n/d Safety Relief Valve Sizing Software
    By azeezy in forum Engineering Spreadsheets & Presentations
    Last Post: 03-03-2017, 12:22 PM
  2. emergency relief valve sizing
    By tekes in forum Oil And Gas Process
    Last Post: 01-15-2014, 09:13 PM
  3. Article: Sizing of relief valve for LPG bullet
    By chen4 in forum Home Articles
    Last Post: 11-19-2013, 09:55 PM
  4. Standard for two phase relief valve sizing
    By fucheng in forum Safety And Environment
    Last Post: 05-29-2013, 10:24 AM
  5. Relief Valve & Line Sizing Papers
    By MarrsieBoy in forum Engineering Programming
    Last Post: 11-07-2011, 04:23 AM
