Thread: Standard for two phase relief valve sizing
  1. Post Standard for two phase relief valve sizing
    Hi everybody,
    Other than HEM in API, is there any international standard on two phase relief valve sizing?
    thanks.
    Re: Standard for two phase relief valve sizing
    the Omega method discussed in API std. adopts a simplified model for HEM , the limits of the model are discussed in API
    for a discussion of HEM model you may consider other sources as DIERS,
    PRODE PROPERTIES (see prode.com) includes a rigorous (not simplified) solution of HEM as well as HNE and NHNE models,
    herebelow the basis for the different models
    HEM MODEL
    HEM (Homogeneous Equilibrium Model) is based on two assumptions (Homogeneous flow)
    1) velocity of gas an liquid phases are equal
    2) vapor and liquid phase are in thermodynamic equilibrium
    this is a general purpose model which gives good results for a broad range of problems
    HNE MODEL
    in HNE model (Homogeneous Non-Equilibrium Model) the vapor and liquid phases are not in thermodynamic equilibrium,
    HNE has found (Fauske, Schmidt ...) to describe well the behaviour of subcooled fluids which reach two-phase equilibria in a nozzle, pipe
    etc. for example the fluid residence time could be too short for a significant vaporisation.
    SOME APPLICATIONS WITH PRODE PROPERTIES
    Isentropic Nozzle model
    this method allows to design/rate safety/relief devices as PSV etc. for critical and two-phase flow.
    The Isentropic Nozzle model allows to define
    1) HEM Homogeneous Equilibrium (Solution of Mass Flux integral)
    2) HNE Homogeneous Non-equilibrium (HEM with Boling Delay and Gas-Liquid Slip Contributes)
    3) HNE-DS , Homogeneous Non-equilibrium
    4) NHNE Non-homogeneous Non-equilibrium
    see these posts for additional information on these topics
    'http://www.egpet.net/vb/entries/82303-PSV-sizing-with-HEM-%28Homogeneous-Equilibrium-Model%29-limits-of-application'
    'http://www.egpet.net/vb/entries/82302-Comparison-of-Homogeneous-equilibrium-%28HEM%29-VS-NON-equilibrium-%28HNE%29-models'
    in addition to HEM standard (see the description given by Carlo.Stenali) you should be able to find HNE-DS as ISO std.
    all these are included in PRODE PROPERTIES which we utilize for PSV sizing / rating.
  1. D.r.e.s.s.e.r. R/a/n/d Safety Relief Valve Sizing Software
    By azeezy in forum Engineering Spreadsheets & Presentations
    Last Post: 03-03-2017, 12:22 PM
  2. emergency relief valve sizing
    By tekes in forum Oil And Gas Process
    Last Post: 01-15-2014, 09:13 PM
  3. Article: Sizing of relief valve for LPG bullet
    By chen4 in forum Home Articles
    Last Post: 11-19-2013, 09:55 PM
  4. Sizing of relief valve for LPG bullet
    By chen4 in forum Oil And Gas Process
    Last Post: 11-19-2013, 02:03 AM
  5. Relief Valve & Line Sizing Papers
    By MarrsieBoy in forum Engineering Programming
    Last Post: 11-07-2011, 04:23 AM
