Hi..I hope I've posted in the correct location.
Has anyone encountered TRV sizing for liquid tube rupture scenario, meaning, the shell design pressure is higher than the tube design pressure.
Both shell and tube are of liquid type.
For a tube design pressure of 13 barg and shell design pressure of 25 barg, is it safe to assume the tube rupture is caused by a pinhole leak in order to determine the required relief rate?
The shell max operating pressure = 9.5 barg while the tube side max op. Pressure = 5 barg.
Which type of tube rupture assumption should I consider, as there are a few possibilities according to API 521.
And, what type of equation should I use to determine this liquid relief rate? One of my colleague suggested to use the equation in Crane. Does anyone know of any equation from GPSA?
I'm looking forward to more suggestions by fellow engineers who are more experienced in this as it's my first time sizing this scenario. Most of us here rarely encounter this scenario so it would be a gud learning curve as well.
Appreciate all your knowledge sharing, thank you!
