Results 1 to 9 of 9
Thread: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
  1. Unhappy Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Dear all,
    I try install setup.exe aspenone v8.3 in windows 8.1 64bit, but it not working.
    After clicking in setup.exe, it run about 10sec, and getting close.
    I don't know why?
    Who can help me?
    Thanks and best Regards.
    P/s: My computer is asus VL551B, i7 4th, win 8 64 bit.
    Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Run the *.msi file and not the setup.exe
    Example:
    AspenEngineeringV8.0.msi
    AspenEngineeringV8.0_x64.msi
  5. Unhappy Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Quote Originally Posted by atomix View Post
    Example:
    Dear atomix
    I'm try to run AspenEngineeringv8.3_x64.msi but it's not run. I dont understand know (
  6. Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    hi... did you solutions for the problem? i have the same problem even when installing v8.0.
  7. Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Hi, I have the same problem and also couldn't run the .msi file
    Anyone have solved this prob. please help
  9. Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
  10. Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Hi
    No program "pirate" will run on win 8 sp1
    That is what the operating system upgrade.
    You should consider using the software at your own risk.
    The suite of Aspen, when installed on your computer, register and upload your information to the website of aspen.
    The AspenTech company can exercise criminal liability against you.
    Use win 7
    B.R.
  11. Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Hi Lizza Armani
    Use Aspentech One V8.6, No problem when installing
  12. Red face Re: Problem: File setup.exe aspenone v8.3 don't working in windows 8.1 64 bit
    Hi Lizza Armani
  1. Eclipse setup problem
    By flipper in forum Reservoir
    Last Post: 08-22-2013, 02:38 PM
