Thread: Buried and superficial pipelines analisys
    Hi I used AutoPipe for stress analysis in Subsea Pipelines, with ASME code B31.8, but now I work in refinery and i wanna know if the stiffnes of soil for K in Autopipe is the same analisys or I need another considerations.. TY
    (I hope you can undertand me, 'cause I speak a little bit of english)
    Re: Buried and superficial pipelines analisys
    The stiffness of the soil depend on the soil you use. It does not bother, whether the soil is subsea or onshore soil.... Even in autopipe, based on your soil input only the stiffness will be calculated, so for refinery piping use the soil parameters as per the soil report (refer to the Civil department)....
  1. Guide To The Design Of Thrust Blocks For Buried Pressure Pipelines
    By selmagis in forum Pipeline And Fluid Flow
    Last Post: 04-30-2018, 07:04 AM
  2. Guide To The Design Of Thrust Blocks For Buried Pressure Pipelines
    By dinahajjar in forum Pipeline And Fluid Flow
    Last Post: 05-27-2013, 09:52 AM
  3. Replies: 0
    Last Post: 05-19-2013, 11:07 PM
  4. Inspection of Buried Pipelines
    By HugoTavares in forum Materials Science &Corrosion
    Last Post: 04-26-2013, 05:12 PM
  5. Inspection of Buried Pipelines
    By HugoTavares in forum Mechanical Engineering
    Last Post: 03-24-2013, 06:28 PM
