Page 1 of 4 1 2 3 ... LastLast
Results 1 to 12 of 39
Thread: Accidents / Incidents / Near misses
    Sep 2008
    Planet Earth
    Hi Guys,
    As we all know, safety is a day to day learning process, and is best learnt by sharing. We have been so good in this forum sharing Safety related information so far.
    I thought it would be good for us to share the Accidents / Incidents / Near misses experienced in their related industry and will work on Investigation through the experience of experts in this forum. This way I think we will be able to get learn, understand and mitigate such an Accidents in our environment.
    To start with I thought I would start with one of the Incident that I had experienced in my work experience in one of a chemical industry.
    A hydrogenator reactor was filled with solvent (Ethanol) and catalyst (through a catalyst charging pot on top of the reactor) and pressurised with hydrogen upto a pressure of 30 barg. As the hydrogenation reaction (absortion of hydrogen through the solvent) is faster in the initial stages, it took 30 min to stabilise the hydrogen pressure in the reactor. The pressure in the reactor was monitored through the DCS. Suddenly the hydrogen leaked through the catalyst pot and was ignited (hydrogen fires are invisible). immediately the hydrogen was depressurised using nitrogen and the hydrogen fire was put off by the application of fire fighting systems.
    This is just a brief note on the incident, If anyone is interested to proceed with this incident or come with their own incident from their industry they can.
    Let us share, investigate, understand and mitigate.
    Everyone is free to share their own perspective
    Sri
    See More: Accidents / Incidents / Near misses
    Sep 2007
    Alexandria - Egypt
    Blog Entries
    1
    Oct 2008
    Petrol City, Ca Coast
    You can sign up to Chemical Safety Board (
    Sep 2008
    Planet Earth
    Hi Ivanilych,
    Thank you for your references.
    What we are trying to do here is make people come out with the accident / incident / near missed that they face in their industry and others to investigate and understand the problem to ensure it is not repeated in other places.
    Anyhow thank you for your reference
  7. Dear All,
    While surfing net i found these usful article for the current running topic.
    Rail Tank Car Collapse
    Possible Causes of Accident on a Project/ Process
    Thanks & Regards
    Ankit
    Sep 2008
    Planet Earth
    Hi All,
    Hope some of you would have come across the Buncefield Incident. This did give a breakthrough for Explosion modeling and the differences in the present modelling and design of oil storage facilities.
    For those who are not aware of, here is the link which gives the details of the incident investigation, recommendations raised etc . . .
    Great Idea
    Dear All,
    I'm already joint to this useful forum, and it's a good idea Sri2cool4u come over it. And it was not bad idea that the participated friends posted some releated links and thank for both of them. In my opinion, it would be better for us to share A / I / Near miss's that we faced in our industry with our own investigation and comments releted, for sure we cant forget to post pictures and/or illustration for the A/I/N. I think that's what Sri meant?.
    Thanks.
    My threads; saleh_hoydi :
    • #8
      Sep 2008
      Planet Earth
      You are absolutely right soleh, that is how thinks can be learnt the easier and knowledge can be shared. More over this could help us prevent the similar hazard situation in where we work day to day
    • #9
      Confined space fatalities
      What happened?
      􀂃 The two welders were Welding the 36'' final tie
      from piping system to exchanger (1B vessel 1E-
      0604).
      􀂃 After completion of external root and hot pass
      weld on piping connection to vessel (1B vessel 1E-
      0604), one welder made an unauthorized confined
      space entry into the vessel to check welding root
      pass. He was thought that the argon purge was off
      but one valve was not completely closed and one
      purge line remained on. This resulted in the argon
      atmosphere being sustained within the vessel, in
      addition to the removal of the purge plug which
      increased the concentration of argon in the vessel
      as one argon hose was still on and was now leaking
      into the vessel directly. So the first welder
      collapsed, the second entered to affect rescue, but
      unfortunately both welders were overcome by lack
      of oxygen and collapsed inside the vessel.
      كان اللحامان يقومان بعملية اللحام لخط 36 بوصة و هو آخر الوصلات
      .(1B vessel 1E- الخاصة بالمبدل ( 0604
      وبعد الانتهاء من عملية اللحام الخارجي بين الخط و الوعاء , قام أحد
      اللحامين بالدخول الغير مصرح به إلي داخل الوعاء للتأآد من طبقة اللحام
      الأساسي ، ظناً منه أن عملية الكسح بالأرجون قد انتهت ولكن لسوء الحظ
      آان أحد البلوف الخاصة بأحد خطوط الكسح لازال مفتوحاً . مما أدي إلي
      تخلل غاز الأرجون بداخل الوعاء، بالإضافة إلي إزالة سدادة الكسح والتي
      أدت إلي زيادة نسبة غاز الأرجون علي حساب غاز الأآسجين نتيجة وجود
      أحد خطوط الكسح بالأرجون تصب بشكل مباشر داخل الوعاء.
      مما أدي إلي سقوط اللحام مغشياً عليه بداخل الوعاء وقام اللحام الثاني
      بالدخول وراءه رغبة منه في انقاذ زميله مما أدي إلي سقوطه أيضاً في
      الحال.
      MORE DETAILS IN ATTACHED FILE
      Attached Files Attached Files
    • why your are pointing finger, this the first mistake for accident investigation ...
      My threads; splendor :
      • Quote Originally Posted by sri2cool4u View Post
        Hi Guys,
        Sri
        Absolutely
        Maybe most of you already know this up-to-date website, anyway
        Step Change in Safety
        regards
      •    Spons.
      1. Article: Accidents / Incidents / Near misses
        By sri2cool4u in forum Home Articles
        Last Post: 08-10-2013, 03:18 AM
      2. Know the Risk: Learning from Errors and Accidents
        By DORIO in forum Safety And Environment
        Last Post: 04-27-2011, 04:17 PM
      3. T. Kletz - Learning from accidents
        By safetyuser in forum Safety And Environment
        Last Post: 02-28-2011, 10:27 AM
      4. Accidents database
        By str in forum Safety And Environment
        Last Post: 09-29-2009, 09:15 PM
      5. Learning from Accidents
        By mmudassarali in forum Safety And Environment
        Last Post: 12-13-2008, 09:43 PM
