Thread: History match
    History match
    Please be advise which parameters can I play to get good match in oil production rate and oil production total.
    Thank you in advance
    Re: History match
    Attached you'll find a summary table with advisable parameters for modification during history match. Focus on the "water cut column".
    PS: as suggested by Mattax and Dalton (SPE monograph on simulation), those parameters to be modified first during history match are the most uncertain, keeping the most well-known unchanged (whenever possible). I recommend you to make a list of the mot uncertain parameters (use engineering and geologic criteria) and try to get a saturation match by changing these only.
    Attached Files Attached Files
    Re: History match
    Thank you so much.
  1. PVT Match in PROSPER
    By ÇáÌäæÈí ÇáæÍÏæí in forum Oil And Gas Production
    Last Post: 01-11-2014, 12:31 AM
  2. Reservoir Static Pressure match
    By ÏÇæÏ ÍÇÒã in forum Reservoir
    Last Post: 01-17-2013, 03:31 PM
  3. History match question
    By vinomarky in forum Reservoir
    Last Post: 10-10-2011, 10:26 AM
