Thread: Refrigeration System for Hydrocarbon Dew Pointing
  1. Refrigeration System for Hydrocarbon Dew Pointing
    Dear Friends,
    I am working on a Hydrocarbon Dew Pointing system which has Propane Refrigeration system. I want to know the start-up procedure for the unit to avoid the off-spec gas going to the consumers.
    Re: Refrigeration System for Hydrocarbon Dew Pointing
    Initial start up (after a long time shut down) is performed flaring the gas until it is on-spec. Start up gas flow rate should be as low as possible (i.e.: start at 30% turn down). You should have a pressure control valve downstream your hydrocarbon dew pointing system, connected to the flare system, to do this.
    Start up after a trip (a short time shut down) may be performed without flaring, depending on local regulations/ your contract. The plant is still "cold" so it will take a much shorter time to get the gas on spec again (i.e.: 2 hours or less). Gas supply regulations or contract may allow you to deliver off spec gas if it is for a short period of times, for example, 2 hours every 4 months, and in this case you can avoid flaring.
    Best Regards
    Refrigerant database.
    Free Solkane 8.0 for refrigerant Properties. Thermodynamics and Physical.
    Easy to use.
    Attached Files Attached Files
  1. Basics of Refrigeration
    By khaled in forum Mechanical Engineering
    Last Post: 05-10-2015, 03:22 PM
  2. Mechanical refrigeration
    By petroabbes in forum Oil And Gas Process
    Last Post: 05-10-2015, 03:09 PM
  3. Replies: 5
    Last Post: 03-07-2013, 11:49 AM
  4. Refrigeration plant
    By arwa in forum Oil And Gas Process
    Last Post: 09-05-2011, 06:45 AM
