Results 1 to 9 of 9
Thread: Refrigeration plant
    Refrigeration plant
    Hello
    I try to size a station of gaz recovery hat uses the refrigeration plant, I did the HYSYS simulation, I want to give the specification of the refrigeration system
    Have you an active page which can help me!
    Thx
  3. For refrigeration plant once you have done the simulation, you need to just specify the refrigeration duty, refrigerant used and its pressure and temperature conditions for the exchanger where you used the refrigerant. The rest will be done by the vendor.
    Thank you very much for your response amitgoyal1972
    the concern is that I don't know according to which criteria determine the inlet pressure of my raw gas to recover
    There is any bibliography which can help me to do it ??
    Cordially
  6. If you are designing a mechanical refrigeration plant, you may select your inlet pressure a few bars above the outlet pressure required to avoid outlet compression. To help you in a more effective way more information is needed about the context of your plant...
    Thank you for the answer MartinMas
    The situation is that there us no pressure at the inlet . I ll use a compressor to run my process
    I have to fix the pressure and i don't know according to wich parameters .
    On the other hand , how to judge tha the final product is stable? according to wich criteria ?
    Take a look at the file attached
    Many thx
  9. your link doesn't work. Could you re-post it?
    Can I have your e mail?
    I'll send it directely!
    Thank you for your help soroushmn
  11. Hi,
    My email is: soroush.mn@gmail.com
  12. Want to know more
  1. Basics of Refrigeration
    By khaled in forum Mechanical Engineering
    Last Post: 05-10-2015, 03:22 PM
  2. Mechanical refrigeration
    By petroabbes in forum Oil And Gas Process
    Last Post: 05-10-2015, 03:09 PM
  3. complex refrigeration
    By nomanfahmi in forum Oil And Gas Process
    Last Post: 05-10-2015, 03:05 PM
  4. how to size a DX evaporator for refrigeration use?
    By fly_dl in forum Engineering Programming
    Last Post: 09-05-2013, 02:59 PM
