Results 1 to 5 of 5
Thread: difference between reduced bore valves and full bore valves
    Cool difference between reduced bore valves and full bore valves
    Dear All,
    I'am going to buy a ball valve for oi processing system, but wonder between reduced bore ball valve and full bore ball valve. any one with solution please provide an answer.
    Re: difference between reduced bore valves and full bore valves
    Well reduced bore increases the pressure drop across the valve as compared to full bore ball valve. It also depends on the system, the allowable pressure drop.
    Jul 2010
    Bangladesh
    Blog Entries
    2
    you can find your answer by checking these:
    en.wikipedia.org/wiki/Ball_valveý
    thank all
  7. Re: difference between reduced bore valves and full bore valves
    Just to add simple point:
    Full bore valve that's mean the valve bore equal to the valve size; for example if you have 1" full bore valve this mean valve bore equal to 1"Thanks a lot
  1. Replies: 59
    Last Post: 12-15-2018, 11:37 AM
  2. Handbook of Valves and Actuators: Valves Manual International
    By himanshu in forum Mechanical Engineering
    Last Post: 07-02-2018, 05:05 AM
  3. Replies: 1
    Last Post: 05-20-2018, 09:31 PM
  4. Difference between Pressure elief Valve and Thermal Relief Valves
    By tsrc8204 in forum Instrumentation & Control
    Last Post: 05-20-2018, 09:22 PM
  5. Handbook of Valves and Actuators: Valves Manual International,IMPORTANT
    By mkhurram79 in forum Instrumentation & Control
    Last Post: 06-11-2013, 02:15 AM
