Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: PVELITE 2013 working in WIndows 7 64-bit
  1. PVELITE 2013 working in WIndows 7 64-bit
    Guys, anybody have suggestions on how to make it worked in Win 7 64-bit.
    Re: PVELITE 2013 working in WIndows 7 64-bit
    If you don't want to change your OS , you could install pvelite in a virtual machine (virtualbox) with windows xp
  5. Re: PVELITE 2013 working in WIndows 7 64-bit
    gerge22, when you used virtualbox software, did you used the -------- keys from PVELITE 2008?
    yes,of course. First installed PVE2008, -----ed it , then installed PVE2013 , run trial-1.bat, uninstalled PVE2013 , reinstalled PVE2013 => Working PVE 2013
    in 64 bit operating system or 32 bit?
    inside virtualbox you can use either xindows 7 or windows xp but ONLY on 32-bit
  10. Re: PVELITE 2013 working in WIndows 7 64-bit
    thanks, gerge22
    PVelite 2014 !00% working,.. tested myself....
    HTML Code:
    http://examfix.wordpress.com/2014/01/17/intergraph-pvelite-2014-includes/
    Working on all windows verssion X86 x64 Windows 7 windows 8 windows vista xp,,,,, everything.....
  14. Re: PVELITE 2013 working in WIndows 7 64-bit
    please show me how to install it?
  16. #12
    Dear gerge22,
    Following is the link for compress softwares
    version 7400 lastest( without -----)
    version 7320 one year ago (without -----)
    version 6258 -----ed version.( for xp only)
    I would appreciate if you could provide -----s for them.
    secondly, I am using pvelite2014 in virtual box with xp. And it is working fine. I installed it in windows 7 32bit but it is not installing. Please remember that I don`t have network card but I installed Microsoft loopback adapter and gave it a static ip address before installing it in xp and it get installed but I repeated same process in windows 7 but it is not installing.
    What I observe is that in xp by giving a static ip to loop back adapter, it icon blinks at the right bottom of desktop showing msg of connected but in windows 7 its icon show some yellow sign appears giving msg of unidentified network.
    Can you help for installing pvelite 2014 in windows 7 32 bit.
    Looking for your prompt response.
    regards,
  1. Pet 2013.2 exchange with working Intersect 2012.1 or CMG 2013
    By rinrin in forum Engineering Programming
    Last Post: 03-11-2019, 08:02 PM
  2. PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    By notachance in forum Mechanical Engineering
    Last Post: 04-14-2018, 07:58 AM
  3. PVElite 2013
    By CCCP in forum Mechanical Engineering
    Last Post: 07-02-2013, 02:10 PM
