Hello guys
I have question about the pressure connections on process pipe .The standard connection is Process Tap from pipe then the isolation valve then tubing and fittings then goes to instrument valve manifold.
my question is, is there any required distance or standard distance between isolation valve and process tap (pipe).
can anyone give me idea about this.
