Thread: Evaluation of weld beads in water pipe by TOFD method.
  1. Evaluation of weld beads in water pipe by TOFD method.
    It is pleased to communicate with people who share their knowledge.
    I need suggestions on evaluation criteria for inspection of piping welds water (02 meter in diameter) by TOFD method.
    thank
    Mar 2011
    Portugal
    Re: Evaluation of weld beads in water pipe by TOFD method.
    Hello eduluis_88!
    If you are looking for an acceptance criteria I believe you can use one of the following among others:
    ISO 5817
    ASME B31.4 - Pipeline Transportation Systems for Liquids and Slurries
    API 1104 (this is for gas but is usual to adopt the acceptance criteria for water systems)
    But the construction code or standard should say something about this. If you give me this information maybe I can help you further.
    also EN 15617:2009
  6. Re: Evaluation of weld beads in water pipe by TOFD method.
    thank vfq3481 and tassoss , I will check these codes.
  1. Pipe Weld Procedures
    By BornToSin in forum Pipeline And Fluid Flow
    Last Post: 10-01-2014, 10:25 AM
  2. Method Statement for GRE Pipe
    By ahasrap in forum Pipeline And Fluid Flow
    Last Post: 06-25-2013, 05:20 PM
  3. I Am Looking For Document About Manufacture Method Defect Weld Pieces
    By Narch in forum Materials Science &Corrosion
    Last Post: 11-15-2012, 09:02 PM
  4. Replies: 4
    Last Post: 02-14-2011, 07:07 PM
  5. Replies: 2
    Last Post: 08-20-2010, 07:50 AM
