Results 1 to 6 of 6
Thread: Pipe Flow 1: Single-phase Flow Assurance
    Very thanks for Dr. Ove Bratland for offer this Book for free
    [h=Get a copy of the book Pipe Flow 1: Single-phase Flow Assurance]2[/h]
    The free version of the book is for your personal and non-commercial use only. You may not modify, copy, distribute, transmit, display, reproduce, publish, license, create derivative works from, transfer, or sell any information from the book.
    Permission to use the book is granted, provided that (1) the copyright notice as well as the 'for non-commercial use only'-notice appears in all copies, (2) the book is used for informational and non-commercial or personal use only, and (3) no modifications are made. Accredited educational institutions, such as universities, private/public colleges, and state community colleges, may download and reproduce the book for distribution in the classroom. Distribution outside the classroom requires express written permission. Use for any other purpose is expressly prohibited by law, and may result in severe civil and criminal penalties.
    [h=I agree, please
    [link Point to another website Only the registered members can access] To download a compressed version to be saved on your hard-disk, you may prefer to click
    [h=]2[/h]
    Table of Contents
    1.1 The many challenges involved in pipeline projects
    1.1.1 History
    1.1.2 Modern pipelines and their alternatives
    1.1.3 Pipeline politics
    1.1.4 What this book is about
    1.2 Codes and specifications
    1.3 A pipeline project's different phases
    1.3.1 Preliminary planning with feasibility study
    1.3.2 Route selection
    1.3.3 Acquisition of right-of-way
    1.3.4 Various data collection
    1.3.5 Pipeline design
    1.3.6 Legal permits and construction
    1.3.7 Commissioning and start-up
    1.4 How pipe flow studies fit into a pipeline project, and which tools to
    1.5 Different sorts of pipe flow models and calculations
    1.5.1 Single-phase versus multi-phase models
    1.5.2 Steady-state versus transient simulations
    1.5.3 The flow simulation software’s different parts
    1.6 Considerations when simulating pipe flow
    1.6.1 General considerations
    1.6.2 Hydrates and
    1.6.3 Leak detection
    1.6.4 Other features
    1.7 Commercially available simulation software
    1.7.1 Single-phase pipe flow software
    1.7.2 Steady-state multi-phase simulation programs
    1.7.3 Transient simulation software
    1.8 An example of what advanced pipe flow simulations can achieve
    References
    2 Pipe friction
    2.1 Basic theory
    2.1.1 Introduction
    2.1.2 Laminar flow
    2.1.3 Turbulent flow
    2.2 Simple friction considerations
    2.3 Nikuradse’s friction factor measurements
    2.4 What surfaces look like
    2.5 The traditional Moody diagram
    2.6 Extracting more from Nikuradse’s measurements
    2.7 The AGA friction factor formulation
    2.8 Towards a better understanding of the friction in turbulent pipe flow
    2.8.1 Introduction about turbulence
    2.8.2 Quantifying turbulence
    2.8.3 Using Kolmogorov’s theory to construct a Moody-like diagram
    2.8.4 Comparing the theoretical results with other measurements
    2.8.5 Large surface imperfections dominate on non-uniform surfaces
    2.8.6 Friction behaves the same way for all Newtonian fluids.
    2.9 Practical friction factor calculation methods
    2.9.1 The surface-uniformity based modified Moody diagram
    2.9.2 Improving friction factor calculation speed
    2.10 Fitting curves to measurements
    2.11 Friction factor accuracy
    2.12 Tabulated surface roughness data
    2.13 Common friction factor methods
    2.14 Transient friction
    2.15 Other sorts of friction in straight, circular pipes
    2.16 Friction factor summary
    Reference
    s
    3 Friction in non-circular pipes
    3.1 General
    3.2 Partially-filled pipe
    3.3 Rectangular pipe
    3.4 Concentric annular cross-section
    3.5 Elliptic cross-section
    References
    4 Friction losses in components
    4.1 General
    4.2 Valves
    4.3 Bends
    4.4 Welds joining pipe sections
    4.5 Inlet loss
    4.6 Diameter changes
    4.7 Junctions
    References
    5 Non-Newtonian fluids and friction
    5.1 Introduction
    5.2 Pipe flow friction for power-law fluids
    5.3 Pipe flow friction for Birmingham plastic fluids
    5.4 Friction-reducing fluids
    References
    6 Transient flow
    6.1 Mass conservation
    6.2 Momentum conservation
    6.3 Energy conservation
    6.4 Examples to illustrate the conservation equations
    6.4.1 Sloping liquid pipeline with steady-state flow
    6.4.2 Horizontal gas pipeline with isothermal steady-state flow
    6.4.3 Example: Gas pipeline cooling down after stop
    References
    7 Simplified liquid flow solution
    7.1 Main principles
    7.1.1 General
    7.1.2 Involving fluid properties
    7.2 Solving the equations by the characteristics method
    7.2.1 Example: Instantaneous valve closure
    7.3 Boundary conditions in the method of characteristics
    7.3.1 Pipe with constant pressure at the inlet, closed outlet
    7.3.2 Pipe with valve at the outlet
    7.3.3 Valve located any other place than inlet or outlet
    7.3.4 Inline centrifugal pump
    7.3.5 Pump between reservoir and pipe inlet
    7.3.6 Positive displacement pump
    7.3.7 Junction
    7.4 Instantaneous valve closure
    7.4.1 Basic simulations
    7.4.2 Some ways to check the simulations results manually
    7.5 Steady-state network analysis
    7.5.1 General
    7.5.2 Finding initial velocities using the steady-state characteristics method 182
    7.5.3 Steady-state convergence criteria
    7.5.4 Steady-state example
    7.6 Simulating transients in pipe networks, an example
    7.7 Stability considerations
    7.7.1 Frictionless flow
    7.7.2 Flow with laminar friction
    7.7.3 Turbulent flow
    7.7.4 Some effects of the characteristic equations being nonlinear
    7.8 Tracking the liquid
    7.9 Checking simulation results
    7.10 Advantages and limitations when using the method of characteristics
    References
    8 Heat exchange
    8.1 General about heat through layered insulation
    8.2 Heat transfer coefficient between fluid and pipe wall
    8.3 Heat transfer coefficients for the pipe wall, coating and insulation layers
    8.4 Heat transfer coefficient for outermost layer
    8.4.1 Buried pipe
    8.4.2 Above-ground pipe
    8.5 The heat models’ limitations
    8.5.1 Transient versus steady-state heat flow
    8.5.2 Other accuracy considerations
    References
    9 Adding heat calculations to the characteristics method
    9.1 The energy equation’s characteristic
    9.2 Solving the energy equations using the explicit Lax-Wendroff’s method
    9.3 Boundary conditions for the thermo equation
    9.3.1 The problem with lack of neighboring grid-points at the boundary
    9.3.2 Junctions, pumps, valves and other components
    9.4 Determining secondary variables
    9.5 Computing starting values
    9.6 Stability considerations for the energy solution
    9.7 Numerical dissipation and dispersion
    9.7.1 How numerical dissipation and dispersion can affect the simulations
    9.7.2 Easy ways to reduce numerical dissipation and dispersion
    9.7.3 Modern, effective ways to counter dissipation and dispersion
    References
    10 Solving the conservation equations
    10.1 Problem formulation
    10.2 Some initial, simplified considerations
    10.3 The conservation equations’ main properties
    10.4 Selecting time integration and spatial discretization methods
    10.5 How to account for friction and heat in the KT3 scheme
    10.6 Calculating secondary from primary variables
    10.7 Determining indirect fluid properties
    References
    11 Ghost cells
    11.1 Some general considerations
    11.2 Inserting ghost values: A simple method
    11.3 An improved ghost cell approximation
    11.4 Further ghost cell improvements
    11.5 Computing state variables from flux variables
    References
    12 Boundary conditions
    12.1 General
    12.1.1 Boundary condition 1: Pressure source, inflowing fluid
    12.1.2 Boundary condition 2: Pressure source, out-flowing fluid
    12.1.3 Boundary condition 3: Mass flow source, in-flowing fluid
    12.1.4 Boundary condition 4: Mass flow source, out-flowing fluid
    12.2 Selecting boundary conditions in junctions
    12.3 Other boundary conditions
    References
    13 Filling the ghost cells by using the boundary conditions directly
    13.1 General philosophy
    13.2 Mass flow source
    13.2.1 Inflowing fluid
    13.2.2 Outflowing fluid
    13.3 Pressure source
    References
    14 Simulation results and program testing
    14.1 Simulating one of the world’s longest gas pipelines
    14.2 Gas temperature in insulated pipelines
    14.3 Simulating pipe rupture
    14.4 How cooling affects the flow after shutdown
    14.5 Comparing with other simulation programs
    14.6 How to verify gas flow simulations, an overview
    14.6.1 See if the integrations runs at all
    14.6.2 Do the same checks as for liquid flow.
    14.6.3 Checking the boundary and ghost cell approximations for steady-state flow
    14.6.4 Checking the boundary and ghost cell approximations for transient flow
    14.6.5 Check that the program uses correct fluid properties
    14.6.6 Check the heat flow calculations manually
    14.6.7 Increase the velocity until choking occurs
    14.6.8 Things which may confuse result interpretation
    References
    15 Simplified models
    15.1 General
    15.2 Steady-state calculations
    15.3 Fully transient isothermal model
    15.4 Neglecting part of inertia for isothermal flow
    15.5 Neglecting all terms to do with gas inertia
    15.5.1 Model formulation
    15.5.2 Numerical approximations
    15.5.3 Important observations regarding neglecting the gas inertia
    References
    Nomenclature
    [h=
    Re: Very thanks for Dr. Ove Bratland for offer this Book for free
    [h=Simulation programs and exercises to be used with the book Pipe Flow 1]2[/h] [h=Exercise 1: Method of characteristics, liquid flow]2[/h] The simulation program requires the Microsoft .Net framework version 2.0 or later to be installed on the computer. Most modern computers have that installed already. If not it can be downloaded free from Microsoft's home page.
    [link Point to another website Only the registered members can access] [h=Exercise 2: All 3 conservation equations, gas flow]2[/h] The simulation program requires the Microsoft .Net framework version 2.0 or later to be installed on the computer. Most modern computers have that installed already. If not it can be downloaded free from Microsoft's home page.
    [link Point to another website Only the registered members can access] [h=Demonstration for the SEAPOG 5-meeting in Pattaya, Thailand, 20. May 2009.]2[/h] The simulation program requires the Microsoft .Net framework version 2.0 or later to be installed on the computer. Most modern computers have that installed already. If not it can be downloaded free from Microsoft's home page.
    [link Point to another website Only the registered members can access] [h=Stratified flow demonstration, 5th Asian pipeline 28. Oct. 2009]2[/h] The simulation program requires the Microsoft .Net framework version 2.0 or later to be installed on the computer. Most modern computers have that installed already. If not it can be downloaded free from Microsoft's home page.
    Re: ipe Flow 1: Single-phase Flow Assurance
    Re: Pipe Flow 1: Single-phase Flow Assurance
    Mohamed, thank you
    thanks a lot mohamed
    Muhammad Khurram
    No download available
  1. Line Sizing spreadsheet with single Phase & Two Phase Flow
    By ask in forum Mechanical Engineering
    Last Post: 01-05-2017, 07:37 PM
  2. Line Sizing spreadsheet with single Phase & Two Phase Flow excel
    By hswang2 in forum Pipeline And Fluid Flow
    Last Post: 03-28-2015, 12:00 PM
  3. Replies: 6
    Last Post: 05-28-2014, 03:55 PM
  4. Pipe Flow 2: Multi-phase Flow Assurance
    By Mohamed in forum Pipeline And Fluid Flow
    Last Post: 09-02-2013, 03:00 AM
  5. Article: Pipe Flow 2: Multi-phase Flow Assurance
    By Mohamed in forum Home Articles
    Last Post: 05-13-2013, 02:16 AM
