I would like to request someone to share WRC Bulletin Series are as follow.
1. WRC Bulletin No 219 - Experimental Investigation of Limit Loads of Nozzles in Cylindrical Vessels
2. WRC Bulletin No 271 - Methods of Analysis of Bolted Flanged Connections - A Review
3. WRC Bulletin No 314 - Bolted Flanged Connections with Full Face Gaskets
4. WRC Bulletin No 321 - The Dynamic Deformation of Piping
5. WRC Bulletin No 324 - Investigation of Design Criteria for Dynamic Loads on Nuclear Power Piping
6. WRC Bulletin No 329 - Accuracy of Stress Intensification Factors for Branch Connections
7. WRC Bulletin No 335 - A Review of Area Replacement Rules for Pipe Connections in Pressure Vessels and Piping
8. WRC Bulletin No 341 - A Preliminary Evaluation of the Elevated Temperature Behavior of a Bolted Flanged Connection
9. WRC Bulletin No 350 - Design Criteria for Dissimilar Metal Welds
10. WRC Bulletin No 353 - Position Paper on Nuclear Plant Pipe Supports
11. WRC Bulletin No 360 - Stress Indices, Pressure Design and Stress Intensification Factors for Laterals in Piping
12. WRC Bulletin No 367 - Basis of Current Dynamic Stress Criteria for Piping
13. WRC Bulletin No 368 - Stresses in Intersecting Cylinders Subjected to Pressure
14. WRC Bulletin No 372 - Guidelines for Flow-Induced Vibration Prevention in Heat Exchangers
15. WRC Bulletin No 389 - Damping and Resonance of Heat Exchanger Tube Bundles
16. WRC Bulletin No 394 - Simplified Methods for Creep-Fatigue Damage Evaluations and the Application to Life Extension
17. WRC Bulletin No 417 - Design Guide to Reduce Potential for Vibration Caused by Fluid Flow Inside Pipes-Review and Survey
18. WRC Bulletin No 423 - Evaluation of Seismic Response Data For Piping
19. WRC Bulletin No 425 - A Review of Methods for the Analysis of Buried Pressure Piping
20. WRC Bulletin No 432 - Fatigue Strength Reduction and Stress Concentration Factors for Welds in Pressure Vessel and Piping
21. WRC Bulletin No 433 - Fatigue of Butt-Welded Pipe and Effect of Testing Methods - Report
22. WRC Bulletin No 435 - Evaluation of Design Margins for Section VIII, Div. 1 and 2 of the ASME Boiler and Pressure Vessel Code
23. WRC Bulletin No 441 - Development of Rational Static Seismic Analysis Method for Piping Systems
24. WRC Bulletin No 446 - Design and Repair of Buried Pipe
25. WRC Bulletin No 448 - Evaluation of Welded Attachments on Pipe and Elbows
26. WRC Bulletin No 449 - Guidelines for the Design and Installation of Pump Piping Systems
27. WRC Bulletin No 463 - Piping Burst and Cyclic Moment Testing and Standardized Flexibility Factor Method
28. WRC Bulletin No 466 - Behavior of Bellows
29. WRC Bulletin No 473 - External Bending Moments on Bolted Gasketed Joints
30. WRC Bulletin No 492 - Piping System SIFs and Flexibility Analysis Criteria
Thank you for your kindness.
Noppakhun
