Thread: Intergraph® SmartPlant® Process Safety
    [h=Improve safety by reducing risk in capital projects and plant operations]2[/h] Intergraph SmartPlant Process Safety is next-generation software that streamlines process safety review and builds your corporate safety knowledge base, leading to considerable benefits for capital projects and your operating plant. By automatically identifying hazards from the plant’s schematic drawings using SmartPlant P&ID, Intergraph SmartPlant Process Safety enables companies to:
    • Produce consistent, high-quality HAZOP study reports for much less time and cost across the complete design
    • Identify and eliminate hazards early in the design process, before change becomes limited and expensive
    • Quickly and easily assess the effect of change on the safety
      of the entire plant
    • Take advantage of action management to execute risk reductions
    [link Point to another website Only the registered members can access] For capital projects, SmartPlant Process Safety leads to lower risk, improved design quality, and reduced schedules. For the operating plant, it means that through better Management of Change (MOC) processes, you can achieve improved and much faster re-HAZOPs and also increase plant safety. Powered by HAZID, SmartPlant Process Safety is an integral part of Intergraph’s world-leading SmartPlant Enterprise process design and asset management suite.
    http://www.intergraph.com/products/ppm/smartplant/process_safety/default.aspx
    Re: Intergraph® SmartPlant® Process Safety
