Thread: Prssure Derivative For Drawdown Test
    Sep 2007
    Alexandria, Egypt, Egypt
    Hi all , i have a question in paper "Interpretation of Multirate Tests by the Pressure Derivative - I. Oil Reservoirs" SPE 53935 ,copy attached
    in Example 1 when calculating :Prssure Derivative For Drawdown Test, i donot know the equation he used to get the highlighted results for derivative , could u help me with the equation.
    Nov 2008
    Australia
    Re: Prssure Derivative For Drawdown Test
    Are you sure it is a derivative? From the image, it is titled simply as "dp", with the units psi. If it were a derivative it would be psi/hr or psi/bbl or whatever the derivative was respect to
    Edit: Had a quick look at the paper, and it does appear to be the derivative of the delta P wrt time (units dont seem to be correct). If I just use a simple linear slope between points I get similar numbers but not exactly the same, so dont know exactly how they are arriving at their derivative
    ie first point I would get (938 - 883)/(1.5 - 1) = 110 vs 124, and second point I would get;
    (965 - 938)/(1.89 - 1.5) = 69 vs 75
    Perhaps they are using a derivative from a curve fit instead - try plotting up the dp's and dt's, fit an equation then take derivative of that equation and see what you get
    Sep 2007
    Thanks vinomarky ,it seems reasonable
    Amahaminer, is there another methods of aproximation of the derivatives for greater accuracy, try to investigate about the "five-points" and "three-point" aproximation methods (or balanced difference quotient) in any Numerical Analysis book. This will produce a smooth derivative curve for easy analysis.
  1. prssure vessel book
    By vikaschaurasia in forum Mechanical Engineering
    Last Post: 06-28-2013, 11:46 PM
  2. Derivative smoothing,paper request
    By amahaminer in forum Reservoir
    Last Post: 01-11-2013, 04:25 PM
  3. Build Up and Drawdown Time estimation
    By ahmedj9579 in forum Reservoir
    Last Post: 04-27-2012, 07:23 PM
  4. Derivative Plots-well Testing
    By M Turab Mehdi in forum Reservoir
    Last Post: 04-26-2011, 09:33 PM
  5. Replies: 6
    Last Post: 03-11-2011, 09:04 AM
