Thread: Water
  1. Question Water
    What are all the standards available for DM water production, polished water production, Potable water production, Cooloing water?
    Apr 2012
    Monterrey, Nuevo Leon, Mexico, Mexico
    Re: Water
    Hello,
    Demi Water Quality is usually around < 40 ppm TDS (Total Dissolved Solids). If you want to know a specific requirement, it all depends on what the application is for your Demi Water Process Requirement. In other words, if you need a Boiler Feed Water Stream, then your Boiler will set the boiler feed water quality requirements. Look for ASME CRTD-vol 34 for boiler feed water specs. The higher the requirements for your final use equipment that requires demi water, the type of feed water changes. I hope this helps.
  1. Water Chemistry- Industrial and Power Station Water Treatment
    By sharmeen in forum Oil And Gas Process
    Last Post: 05-25-2013, 07:05 PM
  2. Replies: 1
    Last Post: 03-30-2011, 01:13 AM
  3. water flow for oil/water coolers
    By giova70 in forum Mechanical Engineering
    Last Post: 02-16-2011, 09:52 PM
  4. Replies: 0
    Last Post: 10-26-2008, 08:54 PM
