Dear all,
I have a real gas - condensate reservoir now, I want to create LGRs (local grid refinement) at near wellbore. But I have a problem with errors. Can you help me to correct this error? Thanks so much.
This is a problem.
@--Message:LGR option enabled
@--Message:Interpolation of Kro/Krg suppressed
@--Message:HCSCAL option deactivated as this is a NOMIX run
@--Message:Only fail-safe SAVE files will be generated
@--Message
@ As well as the 4th argument of REGDIMS, the
@ 11th argument of TABDIMS can also be used to
@ specify the maximum number of flux regions.
@ If both specified, the maximum will be used
@--Comment
@ Argument 1 of GRIDOPTS keyword has been set to
@ allow alternative multipliers
@--Message
@ Argument 2 of GRIDOPTS keyword has been assigned
@ the default value of 0. In this case, FLUXNUM
@ information will be used
@--Warning
@ Argument 3 of GRIDOPTS keyword in not available
@ for use in this release of ECLIPSE 300
@--Message:Checking for licenses
29 Reading INIT
30 Reading GRIDFILE
31 Reading INCLUDE
@--Message:Reading from INCLUDE file INCLUDE\BASE_LOCAL_LMH20
32 Reading PINCH
33 Reading GRIDUNIT
34 Reading SPECGRID
35 Reading COORDSYS
36 Reading COORD
37 Reading ZCORN
38 Reading ACTNUM
39 Reading NTG
40 Reading PERMX
41 Reading PORO
42 Reading ENDINC
43 Reading INCLUDE
@--Message:Reading from INCLUDE file INCLUDE\BASE_LOCAL_FAULTS_LMH20
44 Reading FAULTS
@--Warning
@ FAULTS keyword has been read in without the
@ MULTFLT keyword, or with incorrect MULTFLT records
@ specified. Transmissibilities and diffusivities will
@ not be modified across faults
@--Warning
@ THPRESFT keyword, or with incorrect THPRESFT records
@ specified. Threshold pressure for the fault will
@ not be set up
45 Reading ENDINC
46 Reading COPY
47 Reading MULTIPLY
48 Reading MINPV
49 Reading PINCH
@--Warning
@ Keyword PINCH should only occur once
50 Reading EDIT
@--Message:Processing GRID data
orrtl: severe (157): Program Exception - access violation
mage PC Routine Line Source
tdll.dll 774543D0 Unknown Unknown Unknown
tdll.dll 774535A7 Unknown Unknown Unknown
tdll.dll 77453492 Unknown Unknown Unknown
ernel32.dll 74B714DD Unknown Unknown Unknown
ibifcoremd.dll 1009893F Unknown Unknown Unknown
ibifcoremd.dll 10050133 Unknown Unknown Unknown
ibifcoremd.dll 10056861 Unknown Unknown Unknown
300.exe 00569DB2 Unknown Unknown Unknown
300.exe 00474C00 Unknown Unknown Unknown
300.exe 0040F638 Unknown Unknown Unknown
300.exe 00401FA2 Unknown Unknown Unknown
300.exe 0040111F Unknown Unknown Unknown
300.exe 013ED86A Unknown Unknown Unknown
ernel32.dll 74B733AA Unknown Unknown Unknown
tdll.dll 77459EF2 Unknown Unknown Unknown
tdll.dll 77459EC5 Unknown Unknown Unknown
