Hi Bilal,
Thanks, I was able to change the position of the wells with your help, but I am a bit stuck on how to use the model as a miscible gas CO2, since I am using a black oil model, I read the technical manual, but didnot understood it properly, I wanted to ask you if I can select the Miscible option in the attachment I have forwarded you with this message, it is circled in red. If I select that option, does that means I am using the Miscible CO2 in my simulation or what should I do, would really appreciate your help in this.[link Point to another website Only the registered members can access]
regards
Azeem
