Results 1 to 5 of 5
Thread: Explanation of reservoir related term
  1. Explanation of reservoir related term
    Hello,
    can you please help me to interpret the following :
    "With steady state flow, the drawdown, the average reservoir pressure and flowing bottomhole pressure stays constant as influx into the drainage area equals the voidage"
    What contextual meaning the word "voidage " carries here?
    Thanks.
    Re: Explanation of reservoir related term
    Lets say you have a reservir and are producing q=1000bbl/day from it. Now lets say the reservoir is conncted or it has an aquifer or you are simply injecting into it an amount of I=1000bbl/day. Since the voidage rate q = I (influx) you have a steady state.
  5. Re: Explanation of reservoir related term
    Thanks mate. You made it clear for me.
    Nov 2008
    Australia
    The use of the work voidage is commonly used to make clear that they mean volumes at RESERVOIR CONDITIONS
    As an example, if you are producing oil with Bo = 1.3 at 1,000 stb oil/day, then there would have to be 1,300 reservoir barrels of replacement per day
    The qualitative concept of "Voidage" has been made clear now. In its simple mathematical form, the total reservoir voidage, i.e. the sum of oil, water and gas flows at reservoir conditions is defined as:
    Total Reservoir Voidage = qo*Bo + qw*Bw + (GOR-Rs)qo*Bg
  1. Explanation of the Dow Fire and Explosion Index.
    By mojtaba_pm in forum Safety And Environment
    Last Post: 04-21-2015, 09:27 AM
  2. Explanation of Diffusivity Equation
    By Muhammad Khurram Adil in forum Reservoir
    Last Post: 01-14-2014, 08:33 AM
  3. List of deliverables with explanation FEED
    By VT-engineer in forum Oil And Gas Production
    Last Post: 03-04-2013, 05:19 AM
  4. re: ASTM Table 52 provision/explanation
    By aveno in forum Oil And Gas Process
    Last Post: 07-09-2011, 05:05 PM
