Thread: polytropic compressor simulation with Prode Properties
    I have installed Prode Properties on my computer and I was able to simulate a centrifugal compressor process given the adiabatic efficiency, how can I calculate the same compressor if I know the polytropic efficiency ?
    Thank you very much for help !
    Re: polytropic compressor simulation with Prode Properties
    you can easily solve the polytropic compressor with Prode Properties,
    there is a specific unit in extended version (please contact Prode at 'www.prode.com'),
    that unit solves the model with the desired level of accuracy (it's a iterative procedure),
    however you can obtain equivalent (or very close) results by modeling the polytropic compressor as a series of isentropic units with predetermined polytropic efficiency,
    this is very simple with Prode Properties, for additional information see
    'http://www.prode.com/docs/pppman.pdf'
    -decide the number of steps (I suggest 5 steps) and calculate the dp as (Pout-Pin) / nr. of steps
    -start from compressor inlet temperature and pressure
    -at these conditions calculate cp with the method =StrGCp and cv with the method =StrGCv , calculate k = cp/cv
    -calculate n (polytropic exponent) as n = polytropic efficiency * (k-1)/k
    -calculate P1=Pin+dp and T1 = Tin*(P1/pin)^(n-1)/n
    -at these conditions (P1,t1) calculate cp with the method =StrGCp and cv with the method =StrGCv , calculate k = cp/cv
    -proceed until to complete the steps
    -once you have calculated the final (outlet) temperature you can calculate the enthalpy at inlet conditions (with Prode Properties) as H1 = StrH() and outlet conditions H2 = StrH() the difference being the enthalpy rise in the gas, you can then calculate the polytropic head from polytropic efficiency
  1. WET GAS compression simulation with PRODE PROPERTIES
    By mderra in forum Home Articles
    Last Post: 09-25-2013, 10:31 AM
  2. Prode Properties in VB NET
    By hans23 in forum Engineering Programming
    Last Post: 09-30-2011, 07:25 PM
