Thread: Permeability Calculation
  1. Permeability Calculation
    Dear All,
    I HAVE A WELL, WHICH NEVER BEEN TESTED AND i HAVE ESTIMATED THE OIL RATE from fluid correlation , IS THERE A WAY TO CALCULATE FORMATION PERMEABILITY FROM THE RATE PLEASE.
    REGARDS,
    Re: Permeability Calculation
    By knowing the rest of parameters in Darcy eq. you can estimate effective perm to the flowing phase by simply solving for it (provided you use the right formulation for steady or pseudo-steady state, depending upon your case)
    if well wasn't tested and you estimated oil rate from equation/correlation then you have made assumption on well PI or permeability somewhere.
    Jan 2009
    ALA, KZ
    the only way to calculate perm is from rock type (sand,carbonate, deposition depth, porosity )
    knowing that you can search for correlations
    for exmp permiability of sand is in magnitude from 10- 1000 md
    and carbonate from 0.1 to 10 md
    matrix only
  1. Absolute permeability
    By ibtisam01 in forum Reservoir
    Last Post: 03-13-2014, 06:42 PM
  2. Replies: 4
    Last Post: 02-10-2014, 10:43 PM
  3. Relative Permeability
    By adadsads in forum Laboratory Measurements
    Last Post: 06-03-2013, 09:25 AM
  4. Porosity-Permeability
    By LOST in forum Reservoir
    Last Post: 07-08-2011, 10:25 PM
  5. What is Permeability Ratio Kc/Kf
    By anihita in forum Reservoir
    Last Post: 06-09-2011, 06:59 PM
