Results 1 to 5 of 5
Thread: How to attached files here?
  1. How to attached files here?
    Good day to all!
    I would like to ask how to attached files here?
    Re: How to attached files here?
    Follow:
    Hi stephenbenetjgc:
    1-Go to the Forum where you want to start a thread or to create a post in an existing thread.
    2-Log in in the Forum.
    3-If you are going to reply to a thread, click on the "Go Advanced" button located at the lower right-hand corner of the Quick Reply box (end of the page).
    4-Click on the "Manage Attachments" button located in Additional Options. The "Manage Attachments" window will pop up. Be aware that the valid file extensions are: bmp, doc, gif, jpe, jpeg, jpg, mp3, pdf, png, ppt, pptx, psd, rar, txt, xls, xlsx, and zip. There are also limits to the size of those files.
    5-Click on the "Add Files" button located in the right-hand side. A small box will show up.
    6-Click on the "Select Files" button. The classic "Open" MSWindows will appear. Go to the location your file is located, choose it and click on the "Open" button.
    7-Click on the "Upload Files" button located in the small box that showed up before.
    8-You should see the name of your file in the Attachments section of the "Manage Attachments" window. If you want to attach more files, repeat steps 6 and 7. Otherwise, click on the "Done" button located at the lower right-hand corner.
    9-Finally, click on the "Submit Reply" button located at the right-hand side of the window.
    I tried to write down a very detailed procedure. I hope it is not confusing. A shorter version can be found in "Attachments and Images",
    You are a new member so welcome. I see that you want to share something (giving brings you receiving). I am looking forward that you will be "an uploader/downloader" instead of just "a downloader".
    Quote Originally Posted by f81aa View Post
    hi stephenbenetjgc:
    1-go to the forum where you want to start a thread or to create a post in an existing thread.
    2-log in in the forum.
    3-if you are going to reply to a thread, click on the "go advanced" button located at the lower right-hand corner of the quick reply box (end of the page).
    4-click on the "manage attachments" button located in additional options. The "manage attachments" window will pop up. Be aware that the valid file extensions are: Bmp, doc, gif, jpe, jpeg, jpg, mp3, pdf, png, ppt, pptx, psd, rar, txt, xls, xlsx, and zip. There are also limits to the size of those files.
    5-click on the "add files" button located in the right-hand side. A small box will show up.
    6-click on the "select files" button. The classic "open" mswindows will appear. Go to the location your file is located, choose it and click on the "open" button.
    7-click on the "upload files" button located in the small box that showed up before.
    8-you should see the name of your file in the attachments section of the "manage attachments" window. If you want to attach more files, repeat steps 6 and 7. Otherwise, click on the "done" button located at the lower right-hand corner.
    9-finally, click on the "submit reply" button located at the right-hand side of the window.
    I tried to write down a very detailed procedure. I hope it is not confusing. A shorter version can be found in "attachments and images",
    you are a new member so welcome. I see that you want to share something (giving brings you receiving). I am looking forward that you will be "an uploader/downloader" instead of just "a downloader".
    great stuff as i was also searching for this query from long time and was unable to get a good solution for this query. You provided a -----er solution to attach the files
    thanks for nice info
  1. Replies: 29
    Last Post: 09-09-2016, 10:28 PM
  2. Electrical cable voltage drop calculation excel file attached
    By sandeep_walunj@yahoo.com in forum Instrumentation & Control
    Last Post: 11-20-2013, 02:05 PM
  3. Sofware for .LAS files
    By dhaecl in forum Reservoir
    Last Post: 11-17-2010, 03:44 PM
