Thread: Injection wells in Prosper
    Gents,
    Do any of you know how to design a ESP for an injection well (Yes a water injection well) in Propser. ?
    If not then can you suggest what other s/w can I use to design the same.?
  3. Re: Injection wells in Prosper
    Quote Originally Posted by Tejaswy View Post
    Gents,
    Why don't you use "help" in Prosper. Actually, to design ESP you can use some others. But almost the people like to use Prosper (IPM) beause it's speed than others. And in Prosper, you're not only design ESP but also do many thing.
    Dear Tejaswy,
    simply, you go to option screen and make your well type to be (producer) not injector with ESP artificial lift system, then simply in PVT just make Oil API to be minimum say 5 or even less (you can adjust your parameters from software limit settings), and same for GOR and put salininty value as it's for your injection water.
    secondly, you can go easily to set up your pump design (ESP design section) based on your field conditions.
    This is the only way to get an ESP design for your water injection well.
    Any other inquiry, just let me know and don't hesitate to ask any time.
    Mohamed
    Gents,
  6. Re: Injection wells in Prosper
    Gents,
    ESP is for Producer, why do you put it in injection well? BR.
  1. Article: Injection wells in Prosper
    By Tejaswy in forum Home Articles
    Last Post: 05-05-2014, 04:57 AM
  2. [Prosper] Multilateral Water Injection Well
    By bone in forum Oil And Gas Production
    Last Post: 04-27-2014, 06:32 PM
  3. Acid Gas Injection Wells
    By Robtoran in forum Drilling And Workover
    Last Post: 01-17-2014, 09:30 AM
  4. Water Injection Wells
    By Nunzio_44 in forum Oil And Gas Production
    Last Post: 06-29-2013, 05:35 PM
  5. Waterflooding: Where to put my injection wells?
    By HidayahB in forum Reservoir
    Last Post: 09-23-2012, 05:57 AM
