Results 1 to 6 of 6
Thread: Nickel content in A333 pipe grade 6
  1. Nickel content in A333 pipe grade 6
    Hi,
    Anyone knows how much Nickel content is permissible in A333 ghrade 6 LTCS pipe?
    it shows ... in table 1 of ASTM A333?
  3. Re: Nickel content in A333 pipe grade 6
    Mohammed,
    My 2001 copy of A333 says that there is no Nickel in Grade 6 material. A small residual amount may be present even though it was not intentionally added or specified. If your question is how much would be allowed before the material would be considered to be non-compliant I don't have a clear answer. ASTM A530 and A751 don't discuss limits on non specified materials in pipe. ASTM A20 which is directed at plates for pressure vessels says that unspecified/non-restricted Nickel should be limited to 0.43% in the heat/0.40% in the product. In the services I normally encounter the residual Nickel would not normally present a problem. I guess you will have to rely on your judgement in this matter.
    Regards, Gunnar
    According to ASME II-A (2010) , NO NICKEL IS REQUIRED, SO ANY NI %, WILL BE ACCEPTED
    No nickel in A333 Gr6 it is classified as P1 Gr1 (so no Ni)
  7. Re: Nickel content in A333 pipe grade 6
    we can supply ASTM A333 GR 6 SEAMLESS STEEL PIPE . ANY MORE ENQUIRY , CONTACT ME
    Amy
    Email :qcggamy@hotmail.com Mobile phone:86-18931788358
  9. Re: Nickel content in A333 pipe grade 6
    Amy
  1. Pipe rating and pipe grade
    By megha123 in forum Pipeline And Fluid Flow
    Last Post: 03-20-2014, 09:49 AM
  2. Seamless Pipe Nickel 201 - UNS N02201 ( Werkstoff Nr. 2.4068)
    By ChelseaJack in forum Mechanical Engineering
    Last Post: 01-24-2014, 03:23 PM
  3. Pipe grade & pipe Schedule
    By WAT in forum Pipeline And Fluid Flow
    Last Post: 05-11-2009, 06:02 AM
