Results 1 to 7 of 7
Thread: ECLIPSE PARALLEL Problem on PC
  1. ECLIPSE PARALLEL Problem on PC
    I am trying to Run Eclipse in PARALLEL and I have received the following error from cmd.exe
    Cleaning up...
    Analyzing the input file (it may take a while)...
    Required resources are available. Launching in progress...
    Error Unable to locate Intel MPI installation folder on this machine (chip='defa
    ult', system='pc', --arch='auto'). See troubleshooting section of the ECLRUN man
    ual for more details.
    C:\ecl10.1\eclipse\data>
    Can anyone please over help on how to resolve it.
  3. Re: ECLIPSE PARALLEL Problem on PC
    I have found the solution and I am posting it just incase anyone has a similar problem
    It was an installation problem. A 3rd party software needed to be installed (Intel MPI) by the Admin.
    Cheers
    Would you like to post a guide for MPI installation and how to implement it on eclipse parallel?
  6. Re: ECLIPSE PARALLEL Problem on PC
    powerhouse365 at gmail com
  7. Re: ECLIPSE PARALLEL Problem on PC
    here is the MPI Link:
    [link Point to another website Only the registered members can access] you can run parallel after installing MPI using the RUNSPEC keyword:
    PARALLEL
    4 DISTRIBUTED /
    where 4 is the maximum default number for parallel processors to be used
    Did you run it on your Laptop or on a workstation ( I Desktop computer with 4 CPU installed on its motherboard ) ?
    Just wondering can we run Parallel Eclipse on a Laptop with Core i7 processor which has 4 physical cores ?
    I appreciate if any one has any experience in that and share it with us
  10. Re: ECLIPSE PARALLEL Problem on PC
    Could you please update your MPI link?
  1. How to use eclipse parallel
    By danangnur in forum Reservoir
    Last Post: 10-24-2013, 08:55 AM
  2. Eclipse 300 problem
    By Rafster in forum Reservoir
    Last Post: 04-30-2013, 02:11 AM
