[h=Horsepower]3[/h] Horsepower is the imperial (British) unit of power. A horsepower is the ability to do work at the rate of
- 33,000 ft.lb per min or
- 550 ft.lb per second
Note that Power is "Work per unit time" and work is "Force through distance". In gravity systems Force is Weight - mass multiplied with gravity.
The total horsepower developed by water falling from a given height is the product of the mass flow rate in pounds per minute times the falling height in feet divided by 33,000. It can be expressed as:
Php = mmin h g / 33000 (1)
where
Php = power (horsepower, hp)
mmin = mass flow rate per minute (lbm/min)
h = head or height (ft)
g = acceleration of gravity (32 ft/s2)
(1) can alternatively be expressed as:
Php = msec h g / 550 (1b)
where
msec = mass flow rate per second (lbm/s)
(1) can also be expressed as:
Php = γ Q h / 33000 (1c)
where
Q = volume flow rate (ft3/min)
γ = specific weight (lbf/ft3) (weight is force)
[h=Water Horsepower for Flow in gal/min]4[/h] Water horsepower for flow in gal/min can be expressed as:
Pwhp = SG Qgal h / 3960 (1d)
where
Q = volume flow rate (gpm)
SG = specific gravity
h = head (ft)
SG for water is 1.001 at 32oF and 0.948 at 240oF.
[h=Horsepower due to Certain Head of Water]3[/h] Horsepower of 1 cubic foot of water per minute - efficiency 85%.
[h=Shaft or Brake Horsepower]3[/h] The brake horsepower is the amount of real horsepower going to the pump, not the horsepower used by the motor. In the metric system kilowatts (kW) is used.
Due to hydraulic, mechanical and volumetric losses in a pump or turbine the actual horsepower available for work on or from the fluid is less than the total horsepower supplied.
[h=Shaft or Brake Horsepower for a Pump or Fan]4[/h] The brake horse power - bhp - for a pump or fan can be expressed as:
Pbhp = ( γ Q h / 33000 ) / η (2)
where
Pbhp = brake horse power (horsepower, hp)
Q = volume flow rate (ft3/min, cfm)
η = overall efficiency
[h=Shaft or Brake Horsepower for a Turbine]4[/h] The brake horse power - bhp - for a turbine can be expressed as:
Pbhp = η ( γ Q h / 33000 ) (2b)
[h=Input Horsepower to the Electrical Motor]3[/h] The input horsepower to the electrical motor for a pump or fan can be expressed as:
Php_el = Pbhp / ηe (3)
or
Php_el = (m h / 33000) / (η ηe) (3b)
where
Php_el = input power to the electrical motor
ηe = mechanical efficiency of the electrical motor
[h=Horsepower in Kilowatts and other Units]3[/h] Horsepower can be converted to other common units as:
- 1 hp (English horse power) = 745.7 W = 0.746 kW = 550 ft.lb/s = 2545 Btu/h = 33000 ft.lb/m = 1.0139 metric horse power
Transforming horsepower to kiloWatt can be expressed as:
PkW = 0.746 Php (4)
where
PkW = power (kW)
Together with the equations above it's possible to express (4) in many common combinations as:
PkW = 0,746 (m h / 33000) / η ηe (5)
