[h=Definition of British Horse Power for pumps, fans and turbines - how to convert to other common units]2[/h]Horsepower Horsepower is the imperial (British) unit of power. A horsepower is the ability to do work at the rate of
  • 33,000 ft.lb per min or
  • 550 ft.lb per second
Note that Power is "Work per unit time" and work is "Force through distance". In gravity systems Force is Weight - mass multiplied with gravity.
The total horsepower developed by water falling from a given height is the product of the mass flow rate in pounds per minute times the falling height in feet divided by 33,000. It can be expressed as:
Php = mmin h g / 33000 (1)
where
Php = power (horsepower, hp)
mmin = mass flow rate per minute (lbm/min)
h = head or height (ft)
g = acceleration of gravity (32 ft/s2)
(1) can alternatively be expressed as:
Php = msec h g / 550 (1b)
where
msec = mass flow rate per second (lbm/s)
(1) can also be expressed as:
Php = γ Q h / 33000 (1c)
where
Q = volume flow rate (ft3/min)
γ = specific weight (lbf/ft3) (weight is force)
[h=Water Horsepower for Flow in gal/min]4[/h] Water horsepower for flow in gal/min can be expressed as:
Pwhp = SG Qgal h / 3960 (1d)
where
Q = volume flow rate (gpm)
SG = specific gravity
h = head (ft)
