Thread: Specific speed may be determined independent of the pump size
    Specific speed is a number characterizing the type of impeller in a unique and coherent manner. Specific speed are determined independent of pump size and can be useful comparing different pump designs. The specific speed identifies the geometrically similarity of pumps.
    Specific speed can be expressed as
    Ns = ω q1/2 / h3/4 (1)
    where
    Ns = specific speed
    ω = pump shaft rotational speed (rpm)
    q = flow rate (m3/h, l/s, l/min, m3/min, US gpm, British gpm) at Best Efficiency Point (BEP)
    h = head rise (m, ft)
    Note! When comparing pumps and their documentation be aware of the units used.
    Typical values for specific speed - Ns - for different designs in US units (US gpm, ft)
    • radial flow - 500 < Ns < 4000 - typical for centrifugal impeller pumps with radial vanes - double and single suction. Francis vane impellers in the upper range
    • mixed flow - 2000 < Ns < 8000 - more typical for mixed impeller single suction pumps
    • axial flow - 7000 < Ns < 20000 - typical for propellers and axial fans
    [h=Convert between US units (gpm) and Metric units (m3/h)]3[/h]
    • Ns(US gpm, ft) = 0.861 Ns(m3/h, m)
    • Ns(British gpm, ft) = 0.787 Ns(m3/h, m)
    when
    • 1 US gpm = 0.2271 m3/h
    • 1 British gpm = 0.2728 m3/h
    • 1 ft = 0.3048 m
    [h=Example - Specific Speed for a Pump - with different units]3[/h] A pump has a capacity of 1500 US gal/min (1249 British gpm, 340 m3/h, 94.4 liters/min) at 100 ft (30.5 m) of head and is rotating at 1760 rev/min. Specific speed can be expressed as:
    [h=US gpm, ft]4[/h] Ns(US gpm, ft) = (1760 rev/min) (1500 gal/min)1/2 / (100 ft)3/4
    = 2156
    [h=British gpm, ft]4[/h] Ns(British gpm, ft) = (1760 rev/min) (1249 gal/min)1/2 / (100 ft)3/4
    = 1967
    [h=m3/h, m]4[/h] Ns(m3/h, m) = (1760 rev/min) (340 m3/h)1/2 / (30.5 m)3/4
    = 2500
    [h=liter/min, m]4[/h] Ns(liters/min, m) = (1760 rev/min) (94.4 m3/h)1/2 / (30.5 m)3/4
    = 1317
    Re: Specific speed may be determined independent of the pump size
    Centrifugal pumps and maximum - or shut-off - head
    The maximum or "shut-off" head of a centrifugal pump can be expressed as
    hs = (d n / 1840)2 (1)
    where
    h = head (feet)
    d = outside diameter impeller (inches)
    n = wheel velocity - revolution per minute - (rpm)
  1. [Ask] Beam pump Up&Downstroke Speed
    By rnds in forum Oil And Gas Production
    Last Post: 08-04-2014, 08:29 AM
  2. What´s the criteria to determined the deareator steam vent flow
    By digeca in forum Electrical & Power Engineering
    Last Post: 05-14-2013, 02:06 AM
  3. High specific speed Vertical turbine pumps
    By mlk in forum Mechanical Engineering
    Last Post: 01-17-2012, 06:31 AM
  4. Pumps - Specific Suction Speed
    Last Post: 07-26-2011, 10:09 AM
  5. Specific Speed - Pumps
    Last Post: 07-26-2011, 09:46 AM
