[h=Specific Suction Speed may be used to determine what general pump design to use for maximum efficiency]2[/h]
Suction Specific Speed may be used to determine what pump geometry - radial, mixed flow or axial - to use for maximum efficiency and prevent cavitation. Suction Specific Speed is commonly used as a basis for estimating the safe operating range of a pump.
Suction Specific Speed is dimensionless and are expressed as
Nss = ω q1/2 / NPSHr3/4 (1)Specific Suction Speed can be compared with Specific Speed but instead of using the total head of the pump, the available Net Positive Suction Head N.P.S.H.a is used.
where
Nss = Suction Specific Speed
ω = pump shaft rotational speed (rpm)
q = flow rate capacity (m3/h, l/s, m3/min, US gpm, British gpm) at Best Efficiency Point BEP
NPSHr = pump NPSH required at best efficiency point (m, ft)
As a rule of thumb the Specific Suction Speed should be below 8500 (calculated with US gpm) to avoid cavitation.
