Thread: Viscosity Converting Chart
    The viscosity of a fluid is its resistance to shear or flow, and is a measure of the fluids adhesive/cohesive or frictional properties. This arises because of the internal molecular friction within the fluid producing the frictional drag effect. There are two related measures of fluid viscosity which are known as dynamic and kinematic viscosity.
    Dynamic viscosity is also termed "absolute viscosity" and is the tangential force per unit area required to move one horizontal plane with respect to the other at unit velocity when maintained a unit distance apart by the fluid.
    Centipoise (CPS)
    Millipascal seconds (mPas)
    Poise
    (P)
    Centistokes
    (cSt)
    Stokes
    (S)
    Saybolt Seconds Universal
    (SSU)
    1 0.01 1 0.01 31
    2 0.02 2 0.02 34
    4 0.04 4 0.04 38
    7 0.07 7 0.07 47
    10 0.1 10 0.1 60
    15 0.15 15 0.15 80
    20 0.2 20 0.2 100
    25 0.24 25 0.24 130
    30 0.3 30 0.3 160
    40 0.4 40 0.4 210
    50 0.5 50 0.5 260
    60 0.6 60 0.6 320
    70 0.7 70 0.7 370
    80 0.8 80 0.8 430
    90 0.9 90 0.9 480
    100 1 100 1 530
    120 1.2 120 1.2 580
    140 1.4 140 1.4 690
    160 1.6 160 1.6 790
    180 1.8 180 1.8 900
    200 2 200 2 1000
    220 2.2 220 2.2 1100
    240 2.4 240 2.4 1200
    260 2.6 260 2.6 1280
    280 2.8 280 2.8 1380
    300 3 300 3 1475
    320 3.2 320 3.2 1530
    340 3.4 340 3.4 1630
    360 3.6 360 3.6 1730
    380 3.8 380 3.8 1850
    400 4 400 4 1950
    420 4.2 420 4.2 2050
    440 4.4 440 4.4 2160
    460 4.6 460 4.6 2270
    480 4.8 480 4.8 2380
    500 5 500 5 2480
    550 5.5 550 5.5 2660
    600 6 600 6 2900
    700 7 700 7 3380
    800 8 800 8 3880
    900 9 900 9 4300
    1000 10 1000 10 4600
    1100 11 1100 11 5200
    1200 12 1200 12 5620
    1300 13 1300 13 6100
    1400 14 1400 14 6480
    1500 15 1500 15 7000
    1600 16 1600 16 7500
    1700 17 1700 17 8000
    1800 18 1800 18 8500
    1900 19 1900 19 9000
    2000 20 2000 20 9400
    2100 21 2100 21 9850
    2200 22 2200 22 10300
    2300 23 2300 23 10750
    2400 24 2400 24 11200
    2500 25 2500 25 11600
    3000 30 3000 30 14500
    3500 35 3500 35 16500
    4000 40 4000 40 18500
    4500 45 4500 45 21000
    5000 50 5000 50 23500
    5500 55 5500 55 26000
    6000 60 6000 60 28000
    6500 65 6500 65 30000
    7000 70 7000 70 32500
    7500 75 7500 75 35000
    8000 80 8000 80 37000
    8500 85 8500 85 39500
    9000 90 9000 90 41080
    9500 95 9500 95 43000
    15000 150 15000 150 69400
    20000 200 20000 200 92500
    30000 300 30000 300 138500
    40000 400 40000 400 185000
    50000 500 50000 500 231000
    60000 600 60000 600 277500
    70000 700 70000 700 323500
    80000 800 80000 800 370000
    90000 900 90000 900 415500
    100000 1000 100000 1000 462000
    125000 1250 125000 1250 578000
    150000 1500 150000 1500 694000
    175000 1750 175000 1750 810000
    200000 2000 200000 2000 925000
    Note! The viscosities are based on materials with a specific gravity of one (1).
    Re: Viscosity Converting Chart
    Conversion from absolute to kinematic viscosity is expressed as:
    ν = 6.7197 10-4 μ / γ
    where
    ν = kinematic viscosity (ft2/s)
    μ = absolute or dynamic viscosity (cP)
    γ = specific weight (lb/ft3)
  1. Converting Pump Head to Pressure
    Last Post: 01-26-2012, 01:02 PM
  2. converting segd to segy on the fly
    By bachirgeo in forum Geology & Exploration
    Last Post: 01-23-2012, 10:16 AM
  3. Converting Pump Head to Pressure
    Last Post: 07-26-2011, 11:17 AM
  4. converting pps to ppt
    By vergatario in forum Computer & Internet
    Last Post: 03-19-2010, 01:55 PM
