Since pump curves often are in head - feet or meters, its may be necessary with a conversion to the common pressure scales used in pressure gauges - psi or bar.
[h=Converting Head to Pressure]3[/h] [h=Converting head in feet to pressure in psi]4[/h] Pump curves in feet of head can be converted to pressure - psi - by the expression:
p = 0.434 h SG (1)
where
p = pressure (psi)
h = head (ft)
SG = specific gravity
[h=Converting head in meter to pressure in bar]4[/h] Pump curves in meter of head can be converted to pressure - bar - by the expression:
p = 0.0981 h SG (2)
where
h = head (m)
p = pressure (bar)
[h=Converting head in meter to pressure in kg/cm2]4[/h] Pump curves in meter of head can be converted to pressure - kg/cm2 - by the expression:
p = 0.1 h SG (2b)
where
h = head (m)
p = pressure (kg/cm2)
[h=Converting Pressure to Head]3[/h] Since pressure gauges often are calibrated in pressure - psi or bar, it may be necessary with a conversion to head - feet or meter, commonly used in pump curves.
[h=Converting pressure in psi to head in feet]4[/h] h = p 2.31 / SG (3)
where
h = head (ft)
p = pressure (psi)
[h=Converting pressure in bar to head in meter]4[/h] h = p 10.197 / SG (4)
where
h = head (m)
p = pressure (bar)
[h=Converting pressure in kg/cm2 to head in meter]4[/h] h = p 10 / SG (4b)
where
h = head (m)
[h=Example - Converting Pump Head - feet - to Pressure - psi]3[/h] The pressure - psi - of a water pump operating with head 120 ft can be expressed as:
p = (120 ft) 1 / 2.31
= 52 psi
