Thread: Article: Realtion between pressure and area ?
    You can view the page at
    http://image.gostshare.com/files/ukl1rplu9bdo8koiwmnz.gif
  3. Velocity increases because you transfer same volume from a smaller area.(q=Velocity*Area).
    when you have higher velocities, the flow pattern of the fluid will change and causes pressure drop.
  5. Hi Ameer
    You are right pressure is force per unit area but when talking about a system the pressure remains constant everywhere throughout the system eg. if you consider a pressure vessel connected with nozzle and a pipeline you will see the pressure will be constant thruought the system when its sealed by a valve. Now if you consider flow process pressure drop occurs due to resistance to flow, if you reduce the area of flow it increases the pressure drop.
    you have mixed these two different effects.
    thus if you consider a closed system there would be no pressure change or drop wether its a nozzle or a tank.
    drop is only due to resistance to flow.
    Hope this clears your doubt
  1. Determination of average drainage area pressure
    By pet_spec in forum Reservoir
    Last Post: 04-18-2013, 10:08 PM
  2. Realtion between pressure and area ?
    By ameer in forum Pipeline And Fluid Flow
    Last Post: 06-19-2012, 01:45 AM
  3. Article: Area calculation in Petrel
    By vinomarky in forum Home Articles
    Last Post: 05-01-2012, 12:41 AM
  4. Article: Area calculation in Petrel
    Last Post: 12-28-2011, 08:15 AM
